Number of custom variables
Posted: 05 Oct 2022, 13:55
by chromo23
I sometimes use a lot more than 16 custom variables but just found this in the manual:
- Bildschirmfoto 2022-10-05 um 13.51.33.png (12.56 KiB) Viewed 1806 times
@TD-er can you clarify that?
Re: Number of custom variables
Posted: 05 Oct 2022, 14:02
Hmm that limit has been removed quite a while ago.
Apparently that part of the docs has not yet been updated.
Posted: 05 Oct 2022, 14:23
by chromo23
What is the actual limit?
Posted: 05 Oct 2022, 14:47
chromo23 wrote: ↑05 Oct 2022, 14:23
The amount of memory on the ESP.
The max. variable nr you can use is 2^32 - 1.
It is stored in a std::map, with unsigned int as a key.
Posted: 05 Oct 2022, 14:55
by chromo23
Thanks for pointing out!
