I sometimes use a lot more than 16 custom variables but just found this in the manual:
@TD-er can you clarify that?
Number of custom variables
Re: Number of custom variables
Hmm that limit has been removed quite a while ago.
Apparently that part of the docs has not yet been updated.
The amount of memory on the ESP.
The max. variable nr you can use is 2^32 - 1.
It is stored in a std::map, with unsigned int as a key.
Users browsing this forum: Google [Bot] and 29 guests
