Hi guys, why does the flasher default to this on my computer (cf. jpg) ?
Saving settings I got Pixels Per Inch=288, changing this value like for 96 makes it easy to use. 4k screen ?
Thanks a lot,
Grumpf.
ESP Easy Flasher too small
- 2020-05-02 17_21_14-.jpg (1014.5 KiB) Viewed 6632 times
Re: ESP Easy Flasher too small
Have you tried changing the High DPI settings in the Compatibility tab of the shortcut's Properties page?
Yes you could change that last line in the settings file and it would behave like you wanted next time you open the flasher.
Yeah thanks, it's easy to fix. I just wanted to attract your attention on this strange behavior. Maybe default it to another DPI set ?
Cheers,
Grumpf.
Cheers,
Grumpf.
If I make it bigger 1080 screens will not be enough. But I'm planning on doing a new flasher tool.
Thanks for the quick answer, no biggies. It's easy to workaround.
