Shelly 2.5 as roller blind controller
itguru
#1 Post by itguru » 26 Feb 2020, 20:43
i have build a rule-set for a Shelly 2.5 to control a roller blind.
Maybe this is interessting for somebody.
DeviceConfig:
rules1.txt:
// TaskVar 12:  name=control
//   Var1: name=state
//      Stopped         0
//      RunningUp       1
//      RunningDown     2
//      Initializing    4
//   Var2: name=limit
//      Seconds run: 3-20
//   Var3: name=current
//      CurrentSec:  0=Rollo oben ; Var2=Rollo unten
//   Var4: name=target
// GPIO 4  = up relais     name=relais1up
// GPIO 15 = down relais   name=relais2down
// sw1down
// sw2up
// Timer7 = 1sec timer on up mode
// Timer8 = 1sec timer on down mode
on System#Boot do
   event SystemInit
on SystemInit do
   // Setting the roller blind run time (in sec)
   TaskValueSet 12,2,10
   event StopRunning      //ensure, all is stoped
   TaskValueSet,12,1,4    // start init procedure
   TaskValueSet 12,3,[control#limit]
   TaskValueSet 12,4,0
   event InitUp        //ensure blind is open afer powerswitch/boot
rules2.txt
on sw1up#state=1 do
   if [control#state] <> 4   // on init, switches are not working
      if [control#state] <> 0
         event StopRunning
         TaskValueSet,12,4,0
         if [control#current] > [control#target]
            event RunningUp
on sw2down#state=1 do
         event StopRunning
         TaskValueSet,12,4,[control#limit]
         if [control#current] < [control#target]
            event RunningDown
on StopRunning do       // stopping a posible running up or down move
   timerSet,7,0
   timerSet,8,0
   TaskValueSet,12,1,0
   gpio,4,0
   gpio,15,0
on RunningDown do
   TaskValueSet,12,1,2
   gpio,4,0   // ensure up is off
   gpio,15,1  // activeate Down
   timerSet,7,0
   timerSet,8,1
on RunningUp do
   TaskValueSet,12,1,1
   gpio,15,0  // ensure down is off
   gpio,4,1   // activeate Up
   timerSet,8,0
   timerSet,7,1
on InitUp do
   timerSet,8,0
   timerSet,7,1
On Rules#Timer=8 do // Handle 1sec steps on blind up
   TaskValueSet 12,3,[control#current]+1
   if [control#current] >= [control#target]
      timerSet,8,0
      event StopRunning
      timerSet,8,1
On Rules#Timer=7 do   // Handle 1sec steps on blind up
   TaskValueSet 12,3,[control#current]-1
   if [control#current] <= [control#target]
      timerSet,7,0
      event StopRunning
      timerSet,7,1
rules3.txt
// Remote Interface:
// http://<espeasyip>/control?cmd=event,RunTo=5 = 5 seconds from open
// http://<espeasyip>/control?cmd=event,RunTo=2 = 2 seconds from open
// http://<espeasyip>/control?cmd=event,RunTo=100   total close
// http://<espeasyip>/control?cmd=event,RunTo=0     total open
// http://<espeasyip>/control?cmd=event,RunToClose  total close
// http://<espeasyip>/control?cmd=event,RunToOpen   total open
// State-Informations from control device
on RunToClose do
   if [control#state] <> 4   // on init, no remote commands are allowed
      event RunningDown
on RunToOpen do
      TaskValueSet,12,4,0
      event RunningUp
on RunTo do
      if [control#limit] < %eventvalue%
         if %eventvalue% < 0
            TaskValueSet,12,4,0
            TaskValueSet,12,4,%eventvalue%
      if [control#current] > %eventvalue%
         event RunningUp
         if [control#current] < %eventvalue%
            event RunningDown
megamarco83
Re: Shelly 2.5 as roller blind controller
#2 Post by megamarco83 » 26 Feb 2020, 22:19
wow, compliments!
you did a very good job!
some question from my side.
do you have normal blinds, or venetian?
maybe could be usefull to add the control of venetian blind, that is mainly the same, but with venetian you can control the inclination of venetian
simpy pressing the wall switch1 for 1 second => relay1 will activate in down direction only for 1second, so you can have the inclination.
if you press switch1 longpress (for example > 2000mseconds) you will have relay1 triggered till 100% down / close
same situation for switch2 related to open:
shortpress switch2 => relay2 trigered for 1second, inclication up / open
longpress switch2 => relay2 trigered till reach 100% up / open
second question what's appened if some one switch simmultaneusly switch1 and switch2 ?
the roller shutter motor should be protected to not have relay1 (down/close) and relay1(up/open) triggered simmultaneusly
thanks for replay, and again very very good job!
itguru
#3 Post by itguru » 27 Feb 2020, 11:47
I have "normal" blinds like this ...
https://www.amazon.de/gp/product/B003BVENE4
A colleage of mine have rolers in kind of which you have descripted it. This will be my next job - but not in the next days.
megamarco83
#4 Post by megamarco83 » 27 Feb 2020, 12:01
hi, thanks for reply.
also the "venetian" blind has the same roller shutter motor, the difference is inside the blind itself.
the normal blind can only go up or down
the venetian blind can 1)inclinate up or down and 1)can go up or down as normal blind
the only differences is inside switch: a single press of 1second trygger relay for a second and give an inclination. longpress of switch trigger the relay continuosly and give the motion.
sure no problem, it's just an improvement of your code!
no hurry :-)
maybe another usefull implementation could be send the percentage of position blind to domoticz :-)
but i guess not so easy... :-(
itguru
#5 Post by itguru » 27 Feb 2020, 13:07
megamarco83 wrote: 27 Feb 2020, 12:01 maybe another usefull implementation could be send the percentage of position blind to domoticz :-)
If you you "notify" (send) the "control" Dummy-Device to domoticz, this should send the "seconds from top" in the parameter [control#current]. In [control#limit] is the time (in sec) specifed, the blind need to complete open (or close). If you set these two both integers in relation, you should can calc in your homeautomation a percent value (i think).
I use fhem - and there it works.
hoeby
#6 Post by hoeby » 05 Sep 2020, 18:54
hello Itguru,
Today i reflashed my shelly 2.5
The original fw i flashed with tasmota. But i didn't work proppely. Sometimes the output stopped but the software went on, which resulted in out of sync working.
I have multi espeasy flashed devices in house and they are working beautifull. So when i found your thread, i had to try it.
I flashed it and it works. only have 2 things which i would like to ask.
- The inputs are working like pulse buttons. I give a up command and if goes fully open, same for close.
But is it possible that it works like a normal shutter switch. When i give up i goes up, but stops when i stop controlling the normal switch?
It looks like it goes in a loop with the timers and therefor doesn't read the switch state. Untill it is full up or down. But how to solve this, because you also don't want it to close 1 second, then stop to read the switch state and then again move 1 second
- The control values are in seconds. but is it possible to make the steps smaller?
For ventilation i love to have it at 1,5 seconds from open. But i can't give that command.
Users browsing this forum: Ahrefs [Bot] and 5 guests
