I love the ESPeasy project. Thanks a lot.
Currently I have a application with a hx711 board + 4 weighting Sensor.
For my iPhone I made an iOS application that ask for values every 500mseconds (Json).
Works stable and fine so far.
Is is somehow possible to update the sensor mor often than 1 per second?
This would make my application more accurate.
Frank
Sensorupdate faster than 1 second?
Re: Sensorupdate faster than 1 second?
You would need to compile that yourself then. Currently only once per second for the official builds.
You should also look in the timing stats page to see how long it takes to perform a reading.
I doubt it is possible to do it at a higher frequency.
Thanks a lot for you fast support.
Timing looks good - as I understand-
Read HX711 2ms
Loop: 229ms
I will now try to find the relevant lines in the code a compile a new one.
Frank
Read HX711 2ms
Loop: 229ms
Frank
You can also test with the rules to trigger multiple taskrun calls.
As a hack you can cause some sub-second delay by calling the LongPulse_ms command (see: https://espeasy.readthedocs.io/en/lates ... -available )
This will block for as long as set.
Thanks a lot.
Setting an output pin with
Longpulse_ms
Connected via wire to an input pin, and trigger an action by a change
Works for me.
Maybe there is a software solution, but I am happy for now.
Frank
Longpulse_ms
Works for me.
Frank
Smart Frank !
