ESPEasy R48/R58 - functions and stability
Pf@nne
#1 Post by Pf@nne » 05 Jan 2016, 15:38
since a while I play with my ESP8266.
Now I found the ESPEasy-Sketch for Arduino.
Great work, that is exactly what I´m looking for!
But still I have some problems with functions and stability.
Generally the Sketch works hard with the flash-rom,
so that my own sketches would not run anymore.
Even when I force a rest over the serial console.
(erase flash is shown on the serial console).
Only after a complete reflash of the original firmware (I believe with erasing the flash), my own sketches will run again.
http://www.xess.com/blog/esp8266-reflash/
Also the ESPEasy releases R48 and R58 will run stable.
Right now I use the R48 with PiDome MQTT and everything runs well.
Is it possible to create more than 12 devices?
Yes it is...
#define TASKS_MAX                          64
but the forward button does only work up to 16 devices.
To view the devices > 16 you need to edit the URL manually.
http://192.168.1.30/devices?setpage=5
Which parameter modifies the number of devices on each page?
With the R58 I´m not able to set the MQTT-Broker IP, afer a submit it resets always to 0.0.0.0 again.
Does anybody got the same problem like me or got a hint to solve my problems?
Greetings from Hamburg
Pf@nne
Martinus
Re: ESPEasy R48/R58 - functions and stability
#2 Post by Martinus » 06 Jan 2016, 08:36
Pf@nne wrote:...
Yes it is...
You are right, but you will very likely run into all sorts of unpredictable behavior and errors if you change this. You need to be aware of all the consequences if you change this parameter. Exceeding first limit will start to wipe other configuration areas in flash and exceeding it further may start to write data into a black hole where no flash exists...
The ESP Easy code is currently not written with protection against these things in mind.
Pf@nne wrote:but the forward button does only work up to 16 devices.
The page limit was hardcoded, will be fixed in the next build.
Pf@nne wrote:Which parameter modifies the number of devices on each page?
Currently hardcoded to 4.
Beware that changing this may likely result into low system resources and crash your system.
Question: Why the need for more than 12 tasks?
Pf@nne
#3 Post by Pf@nne » 06 Jan 2016, 21:51
Martinus wrote:Question: Why the need for more than 12 tasks?
I need this for monitoring my heating installation.
Alone the hot water tank needs 10 DS18B20 each 20 cm.
Additionally I want to view the state of the 8 room valves.
Also the puls of the hot water meter.
Right now I use this Sketch:
https://github.com/Pfannex/AktSen
What about this?
Greetings
Pf@nne
