Hi all,
Currently I send data between 2 units with the sendto command.
But I never know if this command arrives, so I just keep sending it every 5 seconds.
Is there another way to communicate in such a way that the receiving unit send a return message?
Best way for inter-unit communication
Re: Best way for inter-unit communication
In that case you should really consider MQTT, that protocol is doing just that - communication from 1 to MANY or MANY to MANY or MANY to 1. Super fast acknowledgement even in 10 000+ clients environment.
thanks, so I believe I need to use publish instead of sendto in that case.
But how do I know the publish action succeeds?
One way is use MQTT import or have the other unit(s) to publish something when they receive a call.
Note that you will need a separate computer running a broker, to use MQTT.
Users browsing this forum: Google [Bot] and 2 guests
