hi,
i discovered some while ago Domoticz. Superbe program.
Found the time to play with it since 2 weeks.
Still a lot to learn but with all available forums help is not difficult to find.
I have studied electronics and program since 30 years.
Already used raspberrys and arduinos in other projects.
Bought until now the following :
raspberry 3, some kaku switch modules, rflink arduino 433 and a 868mhz board, a razberry2 pcb, ....
waiting for the new Thermostaatkraan Spirit from Eurotronic, a nodoMCU (esp8266) module.
Searching for some switch Touch modules like Vhome, Itead (i have the impression that they are all the same but with a diff firmware) ...etc.
You see still a lot to test but i like the combination of pure electronics and programming.
I have a problem / question for the moment so i posted a first topic in the 'RFLink Support Forum - RFLink: Hardware Related discussions' section.
See you,
Hans
Hello from Belgium
Re: Hello from Belgium
welcome! Where are you from (in Belgium )
