Hi sttun
i ask you if it is possible to add support to CAME remote control, i has tryed to do a learning mode but without sucess .
http://www.came.com/global/en/operators ... agner.html
i put here the debud.
CHANNEL 1
OPEN
20;13;DEBUG;Pulses=50;Pulses(uSec)=30,540,480,510,210,210,480,210,480,210,480,510,210,210,510,510,240,510,210,210,480,210,480,510,210,510,210,210,510,210,510,510,240,510,210,510,210,510,210,510,210,210,480,510,210,510,210,510,210,6990;
20;14;DEBUG;Pulses=48;Pulses(uSec)=570,510,210,210,510,210,510,210,510,510,210,210,480,510,240,510,210,210,480,210,510,510,210,510,210,210,510,210,480,510,240,510,210,510,210,510,210,510,210,210,510,510,210,510,210,510,210,6990;
20;15;DEBUG;Pulses=48;Pulses(uSec)=570,510,180,210,480,210,480,210,480,510,180,210,480,510,210,510,180,210,480,210,480,510,180,510,210,210,480,210,480,510,210,510,180,510,210,510,210,510,180,210,480,510,210,510,180,510,180,6990;
20;16;DEBUG;Pulses=50;Pulses(uSec)=270,240,510,510,210,210,480,210,480,210,480,510,180,210,510,510,240,510,210,210,510,210,480,510,210,510,210,210,480,210,510,510,240,510,210,510,210,510,210,510,210,210,480,510,210,510,210,510,210,6990;
STOP
20;23;DEBUG;Pulses=50;Pulses(uSec)=210,240,480,510,210,210,480,210,480,210,510,510,210,210,480,510,210,510,210,210,480,210,480,510,210,510,210,210,480,210,480,510,210,510,210,510,210,510,180,510,210,210,510,510,210,510,210,210,480,6990;
20;24;DEBUG;Pulses=50;Pulses(uSec)=300,240,480,510,210,210,510,210,480,210,480,510,210,210,480,510,210,510,180,210,480,210,480,510,210,510,210,210,480,210,480,510,210,510,180,510,210,510,210,510,210,210,480,510,180,510,210,210,480,6990;
20;25;DEBUG;Pulses=50;Pulses(uSec)=180,240,480,510,210,210,480,210,480,210,480,510,180,210,480,510,210,510,210,210,510,210,480,510,210,510,210,210,480,210,480,510,210,510,210,510,210,510,210,510,210,210,480,510,180,510,180,210,510,6990;
20;26;DEBUG;Pulses=50;Pulses(uSec)=180,240,480,510,210,210,480,210,480,210,480,510,210,210,480,510,210,510,210,210,480,210,480,510,210,510,180,210,510,210,480,510,210,510,210,510,210,510,210,510,180,210,480,510,210,510,210,210,510,6990;
CLOSE
20;27;DEBUG;Pulses=50;Pulses(uSec)=180,240,480,510,210,210,480,210,480,210,510,510,210,210,510,510,240,510,210,210,480,210,480,510,210,510,210,210,510,210,480,510,210,510,210,510,210,510,210,510,180,210,510,510,210,210,510,510,210,6990;
20;28;DEBUG;Pulses=50;Pulses(uSec)=210,240,480,510,210,210,510,210,510,210,480,510,210,210,480,510,210,510,180,210,480,210,510,510,210,510,210,210,480,210,480,510,210,510,180,510,210,510,210,510,210,210,510,510,210,210,480,510,210,6990;
20;29;DEBUG;Pulses=50;Pulses(uSec)=270,240,510,510,210,210,480,210,480,210,480,510,210,210,480,510,210,510,210,210,510,210,510,510,210,510,210,210,480,210,480,510,210,510,210,510,210,510,210,510,210,210,480,510,210,210,480,510,210,6990;
20;2A;DEBUG;Pulses=50;Pulses(uSec)=240,240,480,510,210,210,480,210,480,210,480,510,180,210,480,510,210,510,210,210,480,210,480,510,180,510,180,210,480,210,510,510,210,510,210,510,210,510,210,510,210,210,480,510,180,210,480,510,210,6990;
CHANNEL 2
OPEN
20;3B;DEBUG;Pulses=50;Pulses(uSec)=270,240,510,510,210,210,510,210,480,210,480,480,210,210,480,510,210,510,210,210,510,210,510,510,210,480,210,210,480,210,480,510,210,510,210,510,210,510,210,210,510,210,480,480,210,510,210,510,210,6990;
20;3C;DEBUG;Pulses=50;Pulses(uSec)=330,240,510,510,210,210,480,210,480,210,480,510,210,210,510,510,240,480,210,210,480,210,480,510,210,510,210,210,480,210,510,510,240,480,210,510,210,510,210,210,480,210,480,510,210,510,210,510,210,6990;
20;3D;DEBUG;Pulses=50;Pulses(uSec)=330,240,480,510,210,210,480,210,480,210,480,510,210,210,480,510,240,510,210,210,480,210,480,510,180,510,210,210,480,210,510,510,240,510,210,510,210,510,180,210,480,210,480,510,210,510,210,510,210,6990;
20;3E;DEBUG;Pulses=50;Pulses(uSec)=210,240,480,510,180,210,480,210,480,210,510,510,210,210,480,510,210,510,180,210,480,210,480,510,210,510,210,210,480,210,480,510,210,510,180,510,180,510,210,210,480,210,480,510,210,510,210,510,210,6990;
STOP
20;48;DEBUG;Pulses=50;Pulses(uSec)=270,240,480,510,210,210,510,210,480,210,510,510,210,210,480,510,210,510,180,210,480,210,480,510,210,510,210,210,480,210,480,510,210,510,210,510,180,510,210,210,480,210,480,510,210,510,210,210,480,6990;
20;49;DEBUG;Pulses=50;Pulses(uSec)=270,240,510,510,210,210,480,210,480,210,480,510,210,210,480,510,210,510,210,210,480,210,510,510,210,510,210,210,480,210,480,510,210,510,210,510,210,510,210,210,480,210,480,510,210,510,180,210,480,6990;
20;4A;DEBUG;Pulses=50;Pulses(uSec)=240,240,480,510,210,210,480,210,480,210,480,510,180,210,480,510,210,510,210,210,480,210,480,510,210,510,180,210,480,210,480,510,210,510,210,510,210,510,210,210,480,210,480,510,180,510,210,210,510,6990;
20;4B;DEBUG;Pulses=50;Pulses(uSec)=210,240,480,510,210,210,480,210,480,210,480,510,210,210,480,510,210,510,210,210,480,210,480,510,180,510,210,210,480,210,480,510,210,510,210,510,210,510,180,210,480,210,480,510,210,510,210,210,510,6990;
CLOSE
20;4C;DEBUG;Pulses=50;Pulses(uSec)=270,240,480,510,210,210,480,210,510,210,480,510,210,210,480,510,210,510,210,210,480,210,510,510,210,510,210,210,480,210,480,510,210,510,210,510,210,510,210,210,480,210,480,510,210,210,480,510,210,6990;
20;4D;DEBUG;Pulses=50;Pulses(uSec)=180,240,480,510,210,210,510,210,480,210,480,510,180,210,480,510,210,510,210,210,480,210,480,510,210,510,210,210,480,210,480,510,210,510,210,510,210,510,210,210,480,210,480,510,210,210,480,510,210,6990;
20;4E;DEBUG;Pulses=50;Pulses(uSec)=150,240,480,510,210,210,480,210,480,210,480,510,180,210,480,510,210,510,210,210,480,210,480,510,210,510,180,210,480,210,510,510,210,510,210,510,210,510,210,210,480,210,480,510,180,210,480,510,210,6990;
20;4F;DEBUG;Pulses=50;Pulses(uSec)=240,240,480,510,210,210,480,210,480,210,480,510,210,210,480,510,210,510,210,210,480,210,480,510,180,510,210,210,480,210,480,510,210,510,210,510,210,510,180,210,480,210,480,510,210,210,480,510,210,6990;
CHANNEL 3
OPEN
20;54;DEBUG;Pulses=50;Pulses(uSec)=300,240,510,510,210,210,480,210,510,210,510,510,210,210,510,510,240,510,210,210,480,210,480,510,210,510,210,210,510,210,510,510,240,480,210,510,210,210,480,510,210,210,510,510,210,510,210,510,210,6990;
20;55;DEBUG;Pulses=50;Pulses(uSec)=270,240,480,510,210,210,510,210,510,210,480,510,210,210,480,510,210,510,210,210,510,210,510,510,210,510,210,210,480,210,510,510,240,510,210,510,210,210,510,510,210,210,510,510,210,510,210,510,210,6990;
20;56;DEBUG;Pulses=50;Pulses(uSec)=300,240,510,510,210,210,510,210,480,210,480,510,210,210,480,510,240,510,210,210,510,210,510,510,210,510,210,210,510,210,480,510,240,510,210,510,210,210,510,510,210,210,480,510,210,510,210,510,210,6990;
20;57;DEBUG;Pulses=50;Pulses(uSec)=150,240,480,510,210,210,480,210,480,210,480,510,210,210,510,510,210,510,210,210,480,210,480,510,180,510,180,210,510,210,480,510,210,510,210,510,210,210,480,510,180,210,480,510,210,510,210,510,210,6990;
STOP
20;58;DEBUG;Pulses=50;Pulses(uSec)=240,240,510,510,210,210,480,210,480,210,480,510,210,210,510,510,240,510,210,210,480,210,480,510,210,510,210,210,510,210,510,510,240,510,210,510,210,210,480,510,210,210,480,510,210,510,210,210,510,6990;
20;59;DEBUG;Pulses=50;Pulses(uSec)=240,240,510,510,210,210,480,210,510,210,510,510,210,210,480,510,240,510,210,210,480,210,480,510,210,510,210,210,510,210,480,510,240,510,210,510,210,210,480,510,210,210,510,510,210,510,210,210,510,6990;
20;5A;DEBUG;Pulses=50;Pulses(uSec)=180,240,480,510,210,210,510,210,510,210,480,510,210,210,480,510,210,510,210,210,510,210,510,510,210,510,210,210,480,210,480,510,210,510,210,510,210,210,510,510,210,210,480,510,210,510,210,210,510,6990;
20;5B;DEBUG;Pulses=50;Pulses(uSec)=240,240,510,510,210,210,480,210,480,210,480,510,210,210,480,510,240,510,210,210,510,210,480,510,210,510,210,210,480,210,480,510,240,510,210,510,210,210,480,510,210,210,480,510,210,510,210,210,510,6990;
CLOSE
20;5C;DEBUG;Pulses=50;Pulses(uSec)=240,240,480,510,210,210,480,210,480,210,510,510,210,210,510,510,240,510,210,210,510,210,480,510,210,510,210,210,510,210,510,510,240,510,210,510,210,210,480,510,210,210,510,510,210,210,510,510,210,6990;
20;5D;DEBUG;Pulses=50;Pulses(uSec)=240,240,480,510,210,210,510,210,510,210,510,510,210,210,480,510,210,510,210,210,480,210,510,510,210,510,210,210,480,210,480,510,240,510,210,510,210,210,510,510,210,210,510,510,210,210,480,510,210,6990;
20;5E;DEBUG;Pulses=50;Pulses(uSec)=180,240,510,510,210,210,510,210,510,210,480,480,210,210,480,510,210,510,210,210,510,210,510,510,210,510,210,210,480,210,480,510,210,510,210,510,210,210,510,510,210,210,480,510,210,210,480,510,210,6990;
20;5F;DEBUG;Pulses=50;Pulses(uSec)=210,240,510,510,210,210,480,210,480,210,480,510,210,210,510,510,240,510,210,210,510,210,480,510,210,510,210,210,480,210,510,510,240,510,210,510,210,210,480,510,210,210,480,510,210,210,510,510,210,6990;
CHANNEL 4
OPEN
20;60;DEBUG;Pulses=50;Pulses(uSec)=270,240,480,510,210,210,510,210,510,210,510,510,210,210,480,510,210,510,210,210,510,210,510,510,210,510,210,210,480,210,480,510,210,510,210,510,210,210,510,210,510,210,510,510,210,510,210,510,210,6990;
20;61;DEBUG;Pulses=50;Pulses(uSec)=240,240,510,510,210,210,480,210,480,210,480,510,210,210,480,510,240,510,210,210,510,210,510,510,210,510,210,210,480,210,510,510,240,510,210,510,210,210,510,210,480,210,480,510,210,510,210,510,210,6990;
20;62;DEBUG;Pulses=52;Pulses(uSec)=30,30,270,240,510,510,210,210,480,210,480,210,480,510,210,210,510,510,240,510,210,210,480,210,480,510,210,510,210,210,480,210,510,510,240,510,210,510,210,210,480,210,480,210,480,510,210,510,210,510,210,6990;
20;63;DEBUG;Pulses=50;Pulses(uSec)=270,240,480,510,180,210,480,210,480,210,480,510,210,210,480,510,210,510,210,210,480,210,480,510,180,510,210,210,480,210,480,510,210,510,210,510,210,210,480,210,480,210,480,510,210,510,210,510,210,6990;
STOP
20;64;DEBUG;Pulses=50;Pulses(uSec)=390,240,480,510,210,210,480,210,480,210,480,510,210,210,480,510,210,510,210,210,480,210,480,510,210,510,210,210,480,210,480,510,210,510,210,510,210,210,480,210,480,210,480,510,210,510,210,210,510,6990;
20;65;DEBUG;Pulses=50;Pulses(uSec)=330,240,480,510,180,210,480,210,510,210,510,510,210,210,480,510,240,510,210,210,480,210,480,510,210,510,210,210,480,210,510,510,240,510,210,510,210,210,480,210,480,210,510,510,210,510,210,210,510,6990;
20;66;DEBUG;Pulses=50;Pulses(uSec)=210,240,480,510,180,210,480,210,510,210,480,510,210,210,480,510,210,510,180,210,480,210,480,510,210,510,210,210,480,210,480,510,210,510,180,510,180,210,480,210,480,210,480,510,210,510,210,210,480,6990;
20;67;DEBUG;Pulses=50;Pulses(uSec)=360,240,480,510,210,210,480,210,480,210,480,510,180,210,480,510,210,510,210,210,480,210,480,510,210,510,210,210,480,210,480,510,210,510,210,510,210,210,480,210,480,210,480,510,180,510,180,210,480,6990;
CLOSE
20;68;DEBUG;Pulses=50;Pulses(uSec)=240,240,480,510,180,210,480,210,510,210,480,510,210,210,480,510,210,510,210,210,480,210,480,510,210,510,210,210,510,210,480,510,210,510,210,510,180,210,480,210,480,210,480,510,210,210,510,510,210,6990;
20;69;DEBUG;Pulses=50;Pulses(uSec)=150,240,480,510,210,210,480,210,510,210,480,510,210,210,480,510,210,510,180,210,480,210,480,510,210,510,210,210,480,210,480,510,210,510,180,510,180,210,510,210,510,210,510,510,210,210,480,510,210,6990;
20;6A;DEBUG;Pulses=50;Pulses(uSec)=330,240,480,510,210,210,480,210,480,210,480,510,180,210,480,510,210,510,210,210,480,210,480,510,210,510,210,210,480,210,480,510,210,510,210,510,210,210,480,210,480,210,480,510,180,210,480,510,210,6990;
20;6B;DEBUG;Pulses=50;Pulses(uSec)=180,240,480,510,210,210,480,210,480,210,480,510,210,210,480,510,210,510,210,210,480,210,480,510,180,510,180,210,480,210,480,510,210,510,210,510,210,210,480,210,480,210,480,510,180,210,510,510,210,6990;
CHANNEL 5
OPEN
20;6C;DEBUG;Pulses=50;Pulses(uSec)=270,240,480,510,210,210,480,210,510,210,510,510,210,210,510,480,240,510,210,210,480,210,480,510,210,510,210,210,510,210,510,510,240,510,210,210,480,510,210,510,210,210,510,510,210,510,210,510,210,6990;
20;6D;DEBUG;Pulses=50;Pulses(uSec)=270,240,510,510,210,210,510,210,510,210,510,510,210,210,480,510,210,510,210,210,510,210,510,510,210,510,210,210,480,210,480,510,210,510,210,210,510,510,210,510,210,210,510,510,210,510,210,510,210,6990;
20;6E;DEBUG;Pulses=50;Pulses(uSec)=330,240,510,510,210,210,510,210,480,210,480,510,210,210,480,510,210,510,210,210,510,210,480,510,210,510,210,210,480,210,480,510,210,510,210,210,510,510,210,510,210,210,480,510,210,510,180,510,210,6990;
20;6F;DEBUG;Pulses=50;Pulses(uSec)=210,240,510,510,210,210,480,210,480,210,480,510,210,210,510,510,210,510,210,210,480,210,480,510,210,510,180,210,480,210,480,510,210,510,210,210,480,510,210,510,210,210,480,510,180,510,210,510,210,6990;
STOP
20;70;DEBUG;Pulses=50;Pulses(uSec)=300,240,510,510,210,210,480,210,510,210,480,510,210,210,510,510,240,480,210,210,480,210,510,480,210,510,210,210,480,210,510,510,240,510,210,210,510,510,210,510,210,210,480,510,210,510,210,210,510,6990;
20;71;DEBUG;Pulses=50;Pulses(uSec)=300,240,510,480,210,210,510,210,480,210,510,510,210,210,510,510,240,510,210,210,510,210,480,510,210,510,210,210,510,210,510,510,240,510,210,210,480,510,210,510,210,210,510,510,210,510,210,210,510,6990;
20;72;DEBUG;Pulses=50;Pulses(uSec)=300,240,510,510,210,210,510,210,510,210,510,510,210,210,510,480,240,510,210,210,510,210,510,480,210,510,210,210,510,210,510,510,240,510,210,210,480,510,210,510,210,210,510,480,210,480,210,210,510,6990;
20;73;DEBUG;Pulses=50;Pulses(uSec)=180,240,510,510,210,210,510,210,510,210,480,510,210,210,480,510,210,510,210,210,510,210,510,510,210,480,210,210,480,210,480,510,210,510,210,210,510,510,210,510,210,210,480,480,210,510,210,210,510,6990;
CLOSE
20;74;DEBUG;Pulses=50;Pulses(uSec)=210,240,480,510,210,210,480,210,510,210,480,510,210,210,510,510,240,510,210,210,480,210,480,510,210,510,210,210,510,210,510,510,240,510,210,210,480,510,210,510,210,210,510,510,210,210,510,510,210,6990;
20;75;DEBUG;Pulses=50;Pulses(uSec)=150,240,480,510,210,210,480,210,510,210,510,510,210,210,510,510,240,510,210,210,480,210,480,510,210,510,210,210,510,210,510,510,240,510,210,210,480,510,210,510,210,210,510,510,210,210,510,510,210,6990;
20;76;DEBUG;Pulses=50;Pulses(uSec)=240,240,480,510,210,210,510,210,510,210,510,510,210,210,480,510,210,510,210,210,480,210,510,510,210,510,210,210,480,210,480,510,240,510,210,210,480,510,210,510,210,210,510,510,210,210,480,480,210,6990;
20;77;DEBUG;Pulses=50;Pulses(uSec)=240,240,510,510,210,210,510,210,480,210,480,510,210,210,480,510,210,510,210,210,510,210,510,510,210,510,210,210,480,210,480,510,210,510,210,210,510,510,210,510,210,210,480,510,210,210,480,510,210,6990;
This was ON/STOP/OFF/STOP Command
10;rffind=off
20;89;RFFIND=OFF;
10;rffind=on
20;80;RFFIND=ON;
20;81;DEBUG;Pulses=50;Pulses(uSec)=330,240,510,480,210,210,510,210,510,210,510,510,210,210,510,510,240,480,210,210,480,210,510,510,210,510,210,210,510,210,510,480,240,480,210,480,210,510,210,510,210,210,510,510,210,480,210,480,210,6990;
20;82;RFFind;x;8B33EF;9;12;2;
20;83;DEBUG;Pulses=50;Pulses(uSec)=210,240,480,510,210,210,510,210,510,210,510,510,210,210,480,510,210,510,210,210,480,210,510,510,210,510,210,210,480,210,480,510,210,510,180,510,210,510,210,510,210,210,510,510,210,510,210,210,510,6990;
20;84;RFFind;x;8B33ED;8;12;2;
20;85;DEBUG;Pulses=50;Pulses(uSec)=390,240,480,510,210,210,480,210,480,210,480,510,210,210,480,510,210,510,210,210,480,210,480,510,210,510,180,210,480,210,510,510,210,510,210,510,210,510,210,510,210,210,480,510,180,210,510,510,210,6990;
20;86;RFFind;x;8B33EB;8;12;2;
20;87;DEBUG;Pulses=50;Pulses(uSec)=240,240,480,510,180,210,480,210,480,210,480,510,210,210,480,510,210,510,180,210,480,210,480,510,210,510,210,210,480,210,480,510,210,510,180,510,180,510,210,510,210,210,480,510,210,510,210,210,480,6990;
20;88;RFFind;x;8B33ED;8;12;2;
This was the record by learning mode, regonized on domoticz but dont do nothing.
10;RFFind;0;8B33CF;8;12;2; RF Record: 0 ID: 8B33CF S: 08 L: 12 T: 02 - ON
10;RFFind;1;8B33CB;9;12;2; RF Record: 1 ID: 8B33CB S: 08 L: 12 T: 02 - OFF
CAME wagner Blind Remote control
Re: CAME wagner Blind Remote control
is this information good?
Users browsing this forum: Ahrefs [Bot] and 6 guests
