An esp32 is used to monitor a ventilationsystem. It appears that the system crashes after about a month being online. Probably caused by memory problems. As it's hard to figure out how to overcome the grow of used memory I will go for the lazy way : regular reboot. Seems not to be difficult apart from the fact that I do'nt know the correct syntax forcing a reboot by rules. So anyone who can tell me or give a link to information ?
Bart
Syntaxis for reboot via rules
Re: Syntaxis for reboot via rules
For executing a reboot, the aptly named "reboot" command can be used...
Edit: No direct link available, but it's on this documentation page
Of course we are interested in finding the actual cause of this issue, so a few questions:
- What plugins and Controllers are used in that monitoring setup?
- What release of ESPEasy is installed on the system? Have you tried updating to the latest already
- Do you have the Syslog feature active/in use?
Ath, just put in rules reboot? Without any sys or % or ...?
The code was custom made ( by other person) based upon 8266 but that gave way to high processor load. So switched to a 32. Lots of comm has been between TD-er and Johan (the programmer) times ago. It uses modbus from Duco vent system as input. Johan used the code, stripped out all not required for this configuration and compiled. It makes monitoring possible of CO2 values, %open of valves, temp, humidity% , % off vent speed.
Bart
Bart
The only requirement is that the reboot command is in an event handler (on <eventname> do / endon), that is triggered in some way, to be executed.
If you want that reboot to happen, say, every Sunday at 01:00, that could be an event handler like:
This requires some time source, like NTP, GPS or a RTC clock configured.
on System#Clock=Sun,01:00 do
reboot // Reboot every Sunday at 01:00 to help keep the system 'stable'
Or you set a timer for let's say a week from boot.
86400 seconds a day
86400 seconds a day
