I always get this error:
and the device does not get updated in domoticz.http: C001 cnnection failed
I also tried the generic http controller with this Controller Publish command:
/json.htm?param=udevice&type=command&idx=%id%&nvalue=0&svalue=%value%
In both cases I am sure the ip and port is ok.EVENT: http#192.168.1.200=404
SendToHTTP does work:
on DS18b20#Temperature do
SendToHTTP, 192.168.1.200,8080,/json.htm?param=udevice&type=command&idx=61&nvalue=0&svalue=[DS18b20#Temperature]
I run 20230306 - Mega on a Sonoff Dual R2
