Rules again follow-up
Re: Rules again follow-up
#51 Post by Ath » 22 Feb 2023, 21:37
That can't be all rules, as then there is nothing calling this one rule.
To get the full picture I need to see all rules code...
Dick60
#52 Post by Dick60 » 22 Feb 2023, 21:43
This was not the latest solution from IT aadmin but it was alost a full working solution. After my change it worked completely
on UpdateLightIntensity do
  if [Plugin#GPIO#Pinstate#2]=0 and [int#1]=1
    // Manual mode is not active, and no recent motion detected.
    // So we must turn off the lights.
    gpio,10,1
    gpio,13,1
but still it is not logic for me and have my doubt if the variable is loaded.
Add 2 logentry rows of the variables are set but this is all.
on System#Boot do
 Monitor GPIO,0 // PIR sensor
 Monitor GPIO,2 // Manual mode
on GPIO#0=1 do
  // PIR motion detected
    // Manual mode is not active, so we must act on the motion sensor
    timerSet,1,1800 // 30 minutes timer
    let,1,1 // Set variable #1 to indicate we had some motion detected
    LogEntry,"var#1: [var#1] A1"
    asyncevent,UpdateLightIntensity=[serre_lichtmeting#Analog]
on GPIO#2 do
  // Change of "manual mode"
On serre_lichtmeting#Analog do
  asyncevent,UpdateLightIntensity=%eventvalue1%
on Rules#Timer=1 do
  // 30 minutes has past with no motion detected
  let,1,0 // Clear variable #1 to indicate no motion was detected.
  LogEntry,"var#1: [var#1] A2"
    gpio,10,1
    gpio,13,1
    LogEntry,"Intensity: %eventvalue1% pwm: n/a gpio: 0  A"
    // Either manual mode is active, or recently detected motion
    If %eventvalue1%<60
      PWM,16,00
    Elseif %eventvalue1%<450
gpio,10,1
gpio,13,1
LogEntry,"Intensity: %eventvalue1% pwm: n/a gpio: 0  B"
      let,1,2.5*%eventvalue1%-125 // Approximation of the curve
      PWM,16,[int#1]
    Else
      PWM,16,1000
      GPIO,10,1
      GPIO,13,1
      LogEntry,"Intensity: %eventvalue1% pwm: n/a gpio: 0  C"
    Endif
#53 Post by Ath » 22 Feb 2023, 22:02
Not sure why, but your current copy of "on UpdateLightIntensity do" doesn't match with the last edition I gave in post #47.
Can you update that part with a complete copy of that code?
This is what is expected to be in your rules: (Use the "Select all" link at the top and then ctrl-C to copy it completely)
on System#Boot do
on GPIO#0=1 do
on GPIO#2 do
on Rules#Timer=1 do
  if [Plugin#GPIO#Pinstate#2]=0 and [int#1]=0
    gpio,10,0
    gpio,13,0
    If %eventvalue1%<60
      // Option #1 Will turn off 10 and 13 because LightIntensity <60
      GPIO,10,0
      GPIO,13,0
      PWM,16,00
      LogEntry,"Intensity: %eventvalue1% pwm: 0 gpio: 0  B"
      let,1,2.5*%eventvalue1% - 125 // Approximation of the curve
      PWM,16,[int#1]
      GPIO,10,1  // Option 2 Will turn on 10 and 13 because LightIntensity >= 60
      GPIO,13,1
      LogEntry,"Intensity: %eventvalue1% pwm: [int#1] gpio: 1  C"
    Else
      PWM,16,1000
      GPIO,10,1  // Option 3 Will turn on 10 and 13 because LightIntensity >= 450
      GPIO,13,1
      LogEntry,"Intensity: %eventvalue1% pwm: 1000 gpio: 1  D"
    Endif
Dick60
#54 Post by Dick60 » 22 Feb 2023, 22:08
It seems to work now. I see entries in the Log that gpio 10 and 13 are turned on and that is what I missed in the solution I implemented during the day. I test it and hope, tomrrow morning, i get up and movement is is there, the lights turn on. I let you know.
#55 Post by Ath » 22 Feb 2023, 22:14
Great :)
Dick60
#56 Post by Dick60 » 23 Feb 2023, 07:50
this morning the light went on entering the room. The switch Beweging went to 1. After 30 min the lights went out, still Beweging switch had the status 1. In my opinion it has to do somenthing with the vaiables and the 30min timer.
This is the log:
173664848: EVENT: serre_lichtmeting#Analog=194
173664856: ACT : asyncevent,UpdateLightIntensity=194
173664863: EVENT: UpdateLightIntensity=194
173664880: ACT : gpio,10,0
173664883: GPIO : port#10: set to 0
173664885: ACT : gpio,13,0
173664887: GPIO : port#13: set to 0
173664890: ACT : LogEntry,'Intensity: 194 pwm: n/a gpio: 0 A'
173664892: Intensity: 194 pwm: n/a gpio: 0 A
173664941: SW : GPIO=13 State=0 Output value=0
173665036: HTTP : C001 192.168.2.244 GET... HTTP code: 200
173665043: EVENT: Stekkers3_kastverlichting#State=0
173665053: EVENT: http#192.168.2.244=200
173665382: HTTP: GPIO,13,0
173665385: GPIO : port#13: set to 0
#57 Post by TD-er » 23 Feb 2023, 08:00
It is acting on the change of the state.
So, I guess you need to set the timer to turn it off when the PIR state becomes 0 again instead of 1.
on GPIO#0 do
    if %eventvalue1%=1
      // no more motion detected
      // Start timer to turn off lights.
Dick60
#58 Post by Dick60 » 23 Feb 2023, 08:56
Now it seems to work. i'm glad to finish this project. Great work!
#59 Post by TD-er » 23 Feb 2023, 09:17
There is one more corner-case where it might behave unexpectedly...
But this depends on how often the PIR might toggle.
For example, what if your PIR sensor toggles a few times, since you're sitting still and then start moving a lot for a long time.
Then the timer isn't reset if the motion is detected again.
So we simply need to clear the timer when the PIR state becomes '1' and start the timer again when the PIR changes into '0'.
on GPIO#0 do
    if %eventvalue1%=1
      timerSet,1,0 // Clear the timer
Dick60
#60 Post by Dick60 » 23 Feb 2023, 18:22
I just saw your last remark and that sound very logic. Befor I add this part I want to say that everything is working now. As soon as the light intensity came above 60 and movement was detected, the lidstrip went on. I add the new part so it is approaching the point of perfection, :D :D
