New request, now in the correct forum.
What do i wrong?
This rule is working:
On PIR#Motion do // Motion detected:
if %systime% > 18:48 // After 18:48 Sunset
gpio,12,1 // Lamp on
timerSet 1,60 // start timer
if %systime% < 6:30 // Before 6:30 Sunrise
timerSet 1,60 // start timer//
endOn
On Rules#Timer=1 do
gpio,12,0 // Lamp off
endOn
This is not working:
if %systime% > %Sunset% // After 18:48 Sunset
if %systime% < %Sunrise% // Before 6:30 Sunrise
endOn
On Rules#Timer=1 do
endOn
What do i wrong with this rule [Solved]
Re: What do i wrong with this rule
Answer is the same
See: viewtopic.php?f=23&t=8432#p51421
And similar issue: viewtopic.php?f=6&t=5415
This works for me :
if %systime% > %sunset% or %systime% < %sunrise%
LongPulse,4,1,%eventvalue1%
-D
Thanks, it works also for me so the problem is solved.iron wrote: ↑23 Mar 2021, 13:17 This works for me :
if %systime% > %sunset% or %systime% < %sunrise% LongPulse,4,1,%eventvalue1% endif
