Show your Uptime record !
Deennoo
#1 Post by Deennoo » 17 Mar 2016, 14:48
Some Fun on ESP Easy world ??
Share us your Uptime records !
Nothing to win, nothing to lose, just to show that it Works !
Please specify :
- ESP model
- Build
- Sensors,
- Which controlers is update
- Protocole
- Power Supply Spec
Don't know if Martinus allow to post pictures...
Mine is :
ESP 01
Build 38
DS18b20 + Pulse sensors
Domoticz
HTTP
230 -> 12v -> 3.3 v without condo
cherowley
Re: Show your Uptime record !
#2 Post by cherowley » 17 Mar 2016, 15:10
Lol! I was just going to suggest this Deenooo in the other thread!
I'll get the ball rolling:
ESP model: Sonoff
Build: 48
Sensors: Std hardware with no additional gpio/sensors
Controller: Domoticz
Protocol: Http
Power Supply Spec: N/A
Hardware: Sonoff
Uptime: 58684 minutes (40+days)
Edit: Well! Since I connected via the web page to check the current up time it has rebooted as a result!
highroller
#3 Post by highroller » 17 Mar 2016, 15:29
- ESP model Node MCU v2
- Build 78
- Sensors dht11, touch button, 2channel relay,
- controler Domoticz
- Protocole mqtt and http
- Power Supply Spec 5v 1A usb charger
Uptime 31659
rtenklooster
#4 Post by rtenklooster » 17 Mar 2016, 20:21
Schermafbeelding 2016-03-17 om 20.16.58.png (132.71 KiB) Viewed 8022 times
82 days
Schermafbeelding 2016-03-17 om 20.17.48.png (107.38 KiB) Viewed 8022 times
69 days
Also a lot of esp running for a couple of months now.
Notice the first one is running such an old build, no stability issues. It's an esp-07
Richard - Groningen (NL) - Image
maluko
#5 Post by maluko » 18 Mar 2016, 12:23
hi
i have the uptime into domoticz server, but when the esp reboot its appear one big number like this
"Date: 2016-03-17 23:00:00 Value: 18446744073709552000"
Can this be remove on every reboot?
costo
#6 Post by costo » 18 Mar 2016, 15:46
maluko wrote:hi
Reboot your circuit and immediately take a picture. Then post that picture here and you will be declared the winner of the contest :D
