Rules: event script correct?
lumajo
#1 Post by lumajo » 19 Feb 2021, 10:10
i am using ESPEeasy now since a while but I am unsure how to seolve this:
espeasy build is old: 147.
I want to set a timer value shorter during 22h and 6h in the morning. (Bathlight)
As far as I know variables like let,1,10 does not work in this old build.
how can i solve this?
on led_on do
      timerset,1,600
    if %systime%<05:00:00
       timerset,1,180
   if %systime%>22:00:00
       timerset,1,180
     gpio,12,1     // Schaltet Relais
     gpio,13,0     // Schaltet LED
This only sets the timer to 600 instead of 180. Unfortunately "Or" does not work in this old build.
Re: Rules: event script correct?
#2 Post by TD-er » 19 Feb 2021, 11:08
Maybe "else" does work in that old build?
lumajo
#3 Post by lumajo » 19 Feb 2021, 11:45
Yes works, but I have 2 if's means its first loop will be overwritten by the second if-else
#4 Post by Ath » 19 Feb 2021, 11:47
What's blocking you from upgrading to a more recent build of ESPEasy? R147 is ~4 years old...
lumajo
#5 Post by lumajo » 19 Feb 2021, 18:20
Whats blocking me? Basically I am just too lazy. But actually its something I will do, things are so much easier then...:-)
no change of firmware needed: Solution:
on led_on do
    if %systime% > 05:00:00
       timerset,1,600
      timerset,1,180
   if %systime% > 22:00:00
       timerset,1,180
