4x20 LCD custom characters
I added to _P012_LCD.ino possibility to define own characters, using CGRAM feature. It works with my language character as picture shows:
The problem is that it is possibility to define only 8 characters while in my language are 18 characters different to ASCII (9 lower and 9 upper case).
At this moment definitions are static. So now I work on possibility to dynamically define such characters. Of course at the one "page" of display there will be always possibility to use only 8 from 18 characters. But it is enough.
During this work, I came across an obstacle that I "fought" for quite a long time.
Well, if we define anything on the address 0x00 CGRAM, then this character is displayed as "null" (not "space") and the character defined on the address 0x01 is distorted.
However, if we define the same character at address 0x00 and at the same time at address 0x08 (which according to docu is not possible), then the character with address 0x00 is still displayed as "null" but the character with address 0x08 is displayed correctly. In addition, the character with address 0x01 is not distorted.
I realize that all what I write here is completely incompatible with the documentation or examples that are available on the Internet. I wonder now. Is it the fault of particular display copies I bought or is it some "undocumented feature" of the LiquidCrystal_I2C.h library. In particular the lcd.createChar command. Or maybe something else?
Has anyone encountered a similar issue?
EDIT 1
I forgot to write that logs stands that LCD characters code send by LCD command from rule are correct.
EDIT 1
Re: 4x20 LCD custom characters
A bit late to answer but here's my experience : I modified P012 to add some special chars, it works see pic.
00 %08
01 %01
02 No way, not %02 or %09
03 No way, not %03 or %0a
04 %04
05 %05
I'll try with other value but I think 06 and 07 may work so I may just skip 02 & 03...
Here's my script : (copy paste missed up the structure a bit)
_______________________________________________________________________________________________________
When I try to add them to an HTTP URL in order to display them from a Domoticz script, I can call them using that :00 %08
01 %01
04 %04
05 %05
-- ~/domoticz/scripts/dzVents/KitchenClock.lua
-- Send text to LCD attached to a Wemos ESpeasy
return {
active = true,
on = {
timer = {'every minute'}
execute = function(domoticz)
local LCDSTR
-- Script parameters EDIT HERE ***************************************************************************
local Debug = "No"
local MyLCD ="http://172.19.0.221/control?cmd=LCD,"
local MySensor1 = "Room-Pergola" -- outside T & H
local MySensor2 = "Room-Kitchen" -- inside T
local MySensor3 = "Rain Accuweather" -- rain
local MySensor4 = "Wind Accuweather" -- wind
local MySensor5 = "Old Accuweather" -- Fake sensor for previous atmospheric pressure
local MyVar = "BarometricTendency" -- Global variable that store a Char (v,-,^)
-- Functions
function DtoD(x)
local Winder = {"N","NNE","NE","ENE","E","ESE","SE","SSE","S","SSW","SW","WSW","W","WNW","NW","NNW"}
local WinDex = math.floor(x/22.5+0.5)
return Winder[WinDex]
end
-- Main CODE
local outside = domoticz.devices(MySensor1)
local inside = domoticz.devices(MySensor2)
local Srain = domoticz.devices(MySensor3)
local SEwind = domoticz.devices(MySensor4)
local OPressure = domoticz.devices(MySensor5)
local STRG = DtoD(SEwind.direction)
local Btrend = domoticz.variables(MyVar).value
LCDSTR= MyLCD .."1,1,".. os.date("%A") .. "%A0" ..os.date("%d") .."%A0" .. os.date("%B")
os.execute('curl -s ' ..LCDSTR)
LCDSTR = MyLCD .."2,1,Out:" .. string.format("%.1f",outside.temperature) .."%C2%B0C%20"
LCDSTR= MyLCD .."2,14,".. string.format("%.1f",outside.humidity) .."%04" --"%C2%B0H%20"
LCDSTR= MyLCD.. "3,1,In:".. string.format("%.1f",inside.temperature) .."%C2%B0C%20"
LCDSTR= MyLCD .."3,11,Rain:".. string.format("%.1f",Srain.rainRate) .."%20"
LCDSTR= MyLCD .."4,1,Wind:".. STRG .."%20%20"
LCDSTR= MyLCD .."4,12,".. string.format("%.1f",SEwind.speed) .."%05"
LCDSTR= MyLCD .."4,20,".. Btrend
if Debug=="Yes" then
domoticz.log('Temp is ' ..string.format("%.1f",TSensor.temperature))
domoticz.log('Humidity is ' ..string.format("%.1f",TSensor.humidity))
domoticz.log(LCDSTR)
end
end
I added [ code ] tags to your post.
Thanks. I just skipped special char 2 & 3 and. Here's the result and the code:
And for dzVents :
The other dzVents script to store previous pressure to virtual sensor :
#ifdef USES_P012
//#################################### Plugin 012: LCD ##################################################
#include "_Plugin_Helper.h"
// Sample templates
// Temp: [DHT11#Temperature] Hum:[DHT11#humidity]
// DS Temp:[Dallas1#Temperature#R]
// Lux:[Lux#Lux#R]
// Baro:[Baro#Pressure#R]
// Pump:[Pump#on#O] -> ON/OFF
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C *lcd=NULL;
int Plugin_012_cols = 16;
int Plugin_012_rows = 2;
int Plugin_012_mode = 1;
#define PLUGIN_012
#define PLUGIN_ID_012 12
#define PLUGIN_NAME_012 "Display - LCD2004"
#define PLUGIN_VALUENAME1_012 "LCD"
#define P12_Nlines 4 // The number of different lines which can be displayed
#define P12_Nchars 80
boolean Plugin_012(byte function, struct EventStruct *event, String& string)
boolean success = false;
static byte displayTimer = 0;
switch (function)
case PLUGIN_DEVICE_ADD:
Device[++deviceCount].Number = PLUGIN_ID_012;
Device[deviceCount].Type = DEVICE_TYPE_I2C;
Device[deviceCount].VType = SENSOR_TYPE_NONE;
Device[deviceCount].ValueCount = 0;
Device[deviceCount].SendDataOption = false;
case PLUGIN_GET_DEVICENAME:
string = F(PLUGIN_NAME_012);
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_012));
case PLUGIN_WEBFORM_LOAD:
byte choice = PCONFIG(0);
//String options[16];
int optionValues[16];
for (byte x = 0; x < 16; x++)
if (x < 8)
optionValues[x] = 0x20 + x;
optionValues[x] = 0x30 + x;
//options[x] = F("0x");
//options[x] += String(optionValues[x], HEX);
addFormSelectorI2C(F("p012_adr"), 16, optionValues, choice);
byte choice2 = PCONFIG(1);
String options2[2];
options2[0] = F("2 x 16");
options2[1] = F("4 x 20");
int optionValues2[2] = { 1, 2 };
addFormSelector(F("Display Size"), F("p012_size"), 2, options2, optionValues2, choice2);
String strings[P12_Nlines];
LoadCustomTaskSettings(event->TaskIndex, strings, P12_Nlines, P12_Nchars);
for (byte varNr = 0; varNr < P12_Nlines; varNr++)
addFormTextBox(String(F("Line ")) + (varNr + 1), getPluginCustomArgName(varNr), strings[varNr], P12_Nchars);
addRowLabel(F("Display button"));
addPinSelect(false, F("taskdevicepin3"), CONFIG_PIN3);
addFormNumericBox(F("Display Timeout"), F("p012_timer"), PCONFIG(2));
String options3[3];
options3[0] = F("Continue to next line (as in v1.4)");
options3[1] = F("Truncate exceeding message");
options3[2] = F("Clear then truncate exceeding message");
int optionValues3[3] = { 0,1,2 };
addFormSelector(F("LCD command Mode"), F("p012_mode"), 3, options3, optionValues3, PCONFIG(3));
success = true;
case PLUGIN_WEBFORM_SAVE:
PCONFIG(0) = getFormItemInt(F("p012_adr"));
PCONFIG(1) = getFormItemInt(F("p012_size"));
PCONFIG(2) = getFormItemInt(F("p012_timer"));
PCONFIG(3) = getFormItemInt(F("p012_mode"));
char deviceTemplate[P12_Nlines][P12_Nchars];
String error;
if (!safe_strncpy(deviceTemplate[varNr], web_server.arg(getPluginCustomArgName(varNr)), P12_Nchars)) {
error += getCustomTaskSettingsError(varNr);
if (error.length() > 0) {
addHtmlError(error);
success = true;
case PLUGIN_INIT:
if (PCONFIG(1) == 2) {
Plugin_012_rows = 4;
Plugin_012_cols = 20;
} else if (PCONFIG(1) == 1) {
Plugin_012_mode = PCONFIG(3);
//TODO:LiquidCrystal_I2C class doesn't have destructor. So if LCD type (size) is changed better reboot for changes to take effect.
// workaround is to fix the cols and rows at its maximum (20 and 4)
if (!lcd)
lcd = new LiquidCrystal_I2C(PCONFIG(0), 20, 4); //Plugin_012_cols, Plugin_012_rows);
// Setup LCD display
lcd->init(); // initialize the lcd
// GRUMPF
uint8_t tarrow[8] = {0x04,0x0E,0x1F,0x04,0x04,0x04,0x04,0x04};
uint8_t barrow[8] = {0x04,0x04,0x04,0x04,0x04,0x1F,0x0E,0x04};
uint8_t narrow[8] = {0x04,0x0E,0x1F,0x04,0x04,0x1F,0x0E,0x04};
uint8_t degc[8] = {0x08,0x14,0x08,0x03,0x04,0x04,0x04,0x03};
uint8_t degh[8] = {0x08,0x14,0x08,0x05,0x05,0x07,0x05,0x05};
uint8_t ms[8] = {0x1B,0x15,0x15,0x00,0x07,0x04,0x01,0x07};
lcd->createChar(0,tarrow);
lcd->createChar(1, narrow);
lcd->createChar(6, barrow); // 2 & 3 can't be display through HTTP command %2 or %3 bug ?
lcd->createChar(7, degc);
lcd->createChar(4, degh);
lcd->createChar(5, ms);
lcd->backlight();
lcd->setCursor(0,0);
lcd->print(F("ESP Easy Grumpf"));
lcd->setCursor(0,1);
for (int j=0; j<8; j++) {
lcd->write(j);}
displayTimer = PCONFIG(2);
if (CONFIG_PIN3 != -1)
pinMode(CONFIG_PIN3, INPUT_PULLUP);
success = true;
case PLUGIN_TEN_PER_SECOND:
if (!digitalRead(CONFIG_PIN3))
if (lcd) {
lcd->backlight();
case PLUGIN_ONCE_A_SECOND:
if ( displayTimer > 0)
displayTimer--;
if (lcd && displayTimer == 0)
lcd->noBacklight();
case PLUGIN_READ:
LoadCustomTaskSettings(event->TaskIndex, (byte*)&deviceTemplate, sizeof(deviceTemplate));
for (byte x = 0; x < Plugin_012_rows; x++)
String tmpString = deviceTemplate[x];
if (lcd && tmpString.length())
String newString = P012_parseTemplate(tmpString, Plugin_012_cols);
lcd->setCursor(0, x);
lcd->print(newString);
success = false;
case PLUGIN_WRITE:
String cmd = parseString(string, 1);
if (lcd && cmd.equalsIgnoreCase(F("LCDCMD")))
success = true;
String arg1 = parseString(string, 2);
if (arg1.equalsIgnoreCase(F("Off"))){
lcd->noBacklight();
else if (arg1.equalsIgnoreCase(F("On"))){
lcd->backlight();
else if (arg1.equalsIgnoreCase(F("Clear"))){
lcd->clear();
else if (lcd && cmd.equalsIgnoreCase(F("LCD")))
success = true;
int colPos = event->Par2 - 1;
int rowPos = event->Par1 - 1;
String text = parseStringKeepCase(string, 4);
text = P012_parseTemplate(text, Plugin_012_cols);
//clear line before writing new string
if (Plugin_012_mode == 2){
lcd->setCursor(colPos, rowPos);
for (byte i = colPos; i < Plugin_012_cols; i++) {
lcd->print(" ");
// truncate message exceeding cols
if(Plugin_012_mode == 1 || Plugin_012_mode == 2){
for (byte i = 0; i < Plugin_012_cols - colPos; i++) {
if(text[i]){
lcd->print(text[i]);
// message exceeding cols will continue to next line
else{
// Fix Weird (native) lcd display behaviour that split long string into row 1,3,2,4, instead of 1,2,3,4
boolean stillProcessing = 1;
byte charCount = 1;
while(stillProcessing) {
if (++colPos > Plugin_012_cols) { // have we printed 20 characters yet (+1 for the logic)
rowPos += 1;
lcd->setCursor(0,rowPos); // move cursor down
colPos = 1;
//dont print if "lower" than the lcd
if(rowPos < Plugin_012_rows ){
lcd->print(text[charCount - 1]);
if (!text[charCount]) { // no more chars to process?
stillProcessing = 0;
charCount += 1;
//lcd->print(text.c_str());
// end fix
return success;
// Perform some specific changes for LCD display
// https://www.letscontrolit.com/forum/viewtopic.php?t=2368
String P012_parseTemplate(String &tmpString, byte lineSize) {
String result = parseTemplate_padded(tmpString, lineSize);
const char degree[3] = {0xc2, 0xb0, 0}; // Unicode degree symbol
const char degree_lcd[2] = {0xdf, 0}; // P012_LCD degree symbol
result.replace(degree, degree_lcd);
char unicodePrefix = 0xc3;
if (result.indexOf(unicodePrefix) != -1) {
// See: https://github.com/letscontrolit/ESPEasy/issues/2081
const char umlautAE_uni[3] = {0xc3, 0x84, 0}; // Unicode Umlaute AE
const char umlautAE_lcd[2] = {0xe1, 0}; // P012_LCD Umlaute
result.replace(umlautAE_uni, umlautAE_lcd);
const char umlaut_ae_uni[3] = {0xc3, 0xa4, 0}; // Unicode Umlaute ae
result.replace(umlaut_ae_uni, umlautAE_lcd);
const char umlautOE_uni[3] = {0xc3, 0x96, 0}; // Unicode Umlaute OE
const char umlautOE_lcd[2] = {0xef, 0}; // P012_LCD Umlaute
result.replace(umlautOE_uni, umlautOE_lcd);
const char umlaut_oe_uni[3] = {0xc3, 0xb6, 0}; // Unicode Umlaute oe
result.replace(umlaut_oe_uni, umlautOE_lcd);
const char umlautUE_uni[3] = {0xc3, 0x9c, 0}; // Unicode Umlaute UE
const char umlautUE_lcd[2] = {0xf5, 0}; // P012_LCD Umlaute
result.replace(umlautUE_uni, umlautUE_lcd);
const char umlaut_ue_uni[3] = {0xc3, 0xbc, 0}; // Unicode Umlaute ue
result.replace(umlaut_ue_uni, umlautUE_lcd);
const char umlaut_sz_uni[3] = {0xc3, 0x9f, 0}; // Unicode Umlaute sz
const char umlaut_sz_lcd[2] = {0xe2, 0}; // P012_LCD Umlaute
result.replace(umlaut_sz_uni, umlaut_sz_lcd);
return result;
#endif // USES_P012
-- ~/domoticz/scripts/dzVents/KitchenTestClock.lua
return {
active = true,
on = {
local LCDSTR
local Debug = "No"
local CustLCD ="Yes" -- Use Yes for custom LCD characters if you uploaded custom P012 LCD
-- Functions
function DtoD(x)
--print(WinDex)
--print(Winder[WinDex])
end
-- Main CODE
if CustLCD =="Yes" then
LCDSTR = MyLCD .."2,1,Out%A0" .. string.format("%.1f",outside.temperature) .."%07"
LCDSTR= MyLCD.. "3,1,In%A0%A0".. string.format("%.1f",inside.temperature) .."%07"
LCDSTR= MyLCD .."3,11,Rain%A0".. string.format("%.1f",Srain.rainRate) .."%20"
LCDSTR= MyLCD .."4,1,Wind%A0".. STRG
if Btrend == "^" then
LCDSTR= MyLCD .."4,20,%00"
elseif Btrend == "v" then
LCDSTR= MyLCD .."4,20,%06"
LCDSTR= MyLCD .."4,20,%01"
end
LCDSTR = MyLCD .."2,1,Out%A0" .. string.format("%.1f",outside.temperature) .."%C2%B0C"
LCDSTR= MyLCD .."2,14,".. string.format("%.0f",outside.humidity) .."%H"
LCDSTR= MyLCD.. "3,1,In%A0%A0".. string.format("%.1f",inside.temperature) .."%C2%B0C"
LCDSTR= MyLCD .."3,12,Rain%A0".. string.format("%.1f",Srain.rainRate)
LCDSTR= MyLCD .."4,12,".. string.format("%.1f",SEwind.speed) .."m/s"
LCDSTR= MyLCD .."4,20," .. Btrend
end
end
end
-- ~/domoticz/scripts/dzVents/KitchenPressure.lua
-- Modify Global Variable for Pressure
local Debug = "No"
return {
active = true,
on = {
timer = {'every hour'}
execute = function(domoticz, Tendency)
local MySensor1 = "THP Accuweather" -- Pressure
local MySensor2 = "Old Accuweather" -- Pressure Virtual
local MyVariable = "BarometricTendency"
-- Functions
-- Main CODE
local SPressure = domoticz.devices(MySensor1)
local OPressure = domoticz.devices(MySensor2)
local Arrow
if (SPressure.barometer > OPressure.barometer) then
Arrow = "^"
elseif (SPressure.barometer < OPressure.barometer) then
Arrow = "v"
Arrow = "-"
end
domoticz.variables("BarometricTendency").set(Arrow)
if Debug == "Yes" then
print("NewPressure:" ..SPressure.barometer)
print("OldPressure:" ..OPressure.barometer)
end
OPressure.updateBarometer(SPressure.barometer)
end
@mackowiakp could you add instruction on how to add national characters?
I'm not sure where and how to add them.
If you look at my modified P012.ino code, it's below the ////Grumpf////
You just have to create your character and replace it.
https://maxpromer.github.io/LCD-Character-Creator/
Sorry for the long delay in responding, but I was in India. And I came back, not with COVID but with some parasite. And I had to "visit" the Institute of Maritime and Tropical Medicine.@mackowiakp could you add instruction on how to add national characters?
So attached here is the code for the LCD plugin, which contains definitions for Polish national characters.
Only that it works for sure with the ESPEasy_mega-20191208 version. Compiling with newer versions produces some errors. However, I did not deal with adapting this code to newer versions of ESPEasy, because the ESPEasy_mega-20191208 version works perfectly for me, without any HW/SW/Watchdog-reboot. And I will not change anything that works perfectly for me.
Also please read the first post in this thread. I had problems with defining national characters and to this day I do not know whether the fault lies in the type of device or in the particular copy of the device I have. I have not tried this code with another display.
I can add it wrapped in a define for Polish characters, so they don't add to the bin size when not used.
Nice idea!
OK, THX
