Now I just take all files from git source "as is". No Custom.h, normal, default SDK. No my changes except uncomment "#define FEATURE_SD: in default "define_plugin_sets.h" file.
Then from VS terminal run:
[maciek@Piotr ESPEasy-mega-20191123]$ pio lib install "SD"
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/custom_ESP8266_4M1M
LibraryManager: Installing id=161
SD @ 041f788250 is already installed
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/custom_sdk3_ESP8266_4M1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/custom_beta_ESP8266_4M1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/custom_ESP8266_4M2M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/normal_ESP8266_1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/normal_sdk3_ESP8266_1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/normal_ESP8266_1M_VCC
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/normal_ESP8285_1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/normal_WROOM02_2M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/normal_WROOM02_2M256
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/normal_ESP8266_4M1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/normal_ESP8266_16M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/minimal_core_242_ESP8266_1M_OTA
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/minimal_core_242_ESP8285_1M_OTA
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/minimal_core_261_ESP8266_1M_OTA
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/minimal_core_261_ESP8285_1M_OTA
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/minimal_core_261_sdk3_ESP8266_1M_OTA
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/minimal_core_261_sdk3_ESP8285_1M_OTA
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/minimal_IRext_ESP8266_1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/minimal_IRext_ESP8266_4M1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/minimal_IRext_ESP8266_4M2M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/normal_IRext_no_rx_ESP8266_4M2M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/test_ESP8266_4M_VCC
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/test_beta_ESP8266_4M1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/test_beta_ESP8266_16M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/dev_ESP8266_4M1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/hard_SONOFF_POW_4M1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/hard_other_POW_ESP8285_1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/hard_Shelly_1_2M256
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/hard_Ventus_W266
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/custom_ESP32_4M316k
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/test_ESP32_4M316k
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/test_ESP32-wrover-kit_4M316k
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/spec_debug_custom_ESP8266_4M1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/spec_debug_beta_custom_ESP8266_4M1M
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/spec_debug_custom_ESP32_4M316k
Library Storage: /home/maciek/TMP/ESPEasy-mega-20191123/.pio/libdeps/spec_memanalyze_ESP8266
And this is result of compilation. Only SD lib errors.
> Executing task: platformio run --environment normal_ESP8266_4M1M <
Processing normal_ESP8266_4M1M (platform: https://github.com/Jason2866/platform-espressif8266.git#core_2_6_1; board: esp12e; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CPPDEFINES: [['BUILD_GIT', '""'], 'NDEBUG', 'VTABLES_IN_FLASH', 'PIO_FRAMEWORK_ARDUINO_LWIP2_LOW_MEMORY_LOW_FLASH', ['PUYA_SUPPORT', '1'], 'CORE_POST_2_5_0', 'BEARSSL_SSL_BASIC', 'CORE_POST_2_6_0', 'PIO_FRAMEWORK_ARDUINO_ESPRESSIF_SDK22x_190703', ['MQTT_MAX_PACKET_SIZE', '1024'], ['HTTPCLIENT_1_1_COMPATIBLE', '0'], 'USE_CUSTOM_H']
LINKFLAGS: -Wl,-Tesp8266.flash.4m1m.ld
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp12e.html
PLATFORM: Espressif 8266 2.2.4 #043f5fd > Espressif ESP8266 ESP-12E
HARDWARE: ESP8266 80MHz, 80KB RAM, 1019.98KB Flash
PACKAGES: toolchain-xtensa 2.50400.170719 (5.4.0), framework-arduinoespressif8266 2.20601.0 (2.6.1), tool-esptool 1.413.0 (4.13), tool-esptoolpy 1.20800.0 (2.8.0)
Converting ESPEasy.ino
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 59 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <ESPeasySerial> 1.0.13 #7ddbf6c
|-- <ESP8266WiFi> 1.0
|-- <DNSServer> 1.1.1
|-- <ESP8266mDNS> 1.2
|-- <I2Cdevlib-Core>
| |-- <Wire> 1.0
|-- <SD>
| |-- <SPI> 1.0
|-- <SPI> 1.0
|-- <Servo(esp8266)> 1.0.2
|-- <Wire> 1.0
|-- <AS_BH1750>
| |-- <Wire> 1.0
|-- <Adafruit SGP30 Sensor> 1.0.2
| |-- <Wire> 1.0
|-- <Adafruit TCS34725> 1.0.1
| |-- <Wire> 1.0
|-- <Adafruit TSL2591 Library> 1.0.2
| |-- <Adafruit Unified Sensor> 1.0.2
| |-- <Wire> 1.0
|-- <ESP8266_SSD1306> 3.2.7
| |-- <Wire> 1.0
| |-- <SPI> 1.0
|-- <ccronexpr>
|-- <AM2320>
| |-- <Wire> 1.0
|-- <Adafruit MPR121> 1.0.0
| |-- <Wire> 1.0
|-- <Adafruit Motor Shield V2 Library> 1.0.4
| |-- <Wire> 1.0
|-- <Adafruit NeoPixel> 1.0.6
|-- <ArduinoJson> 6.11.0
|-- <Blynk> 0.6.1
|-- <ESP8266HTTPClient> 1.2
|-- <HLW8012> 1.1.1
|-- <CHT16K33 LED Matrix Library> 0.0.1
| |-- <Wire> 1.0
|-- <LiquidCrystal_I2C>
| |-- <Wire> 1.0
|-- <NewPingESP8266>
|-- <MechInputs> 0.0.1
|-- <SDM> 2.0.0
|-- <SparkFun APDS9960 RGB and Gesture Sensor> 1.4.2
| |-- <Wire> 1.0
|-- <TinyGPSPlus> 1.0.2
|-- <SerialSensors> 0.0.1
|-- <RN2xx3 Arduino Library> 1.0.1
|-- <ESP8266WebServer> 1.0
|-- <PubSubClient> 2.7
|-- <ArduinoOTA> 1.0
|-- <ESP8266HTTPUpdateServer> 1.0
Building in release mode
Compiling .pio/build/normal_ESP8266_4M1M/libb59/SD_ID161/File.cpp.o
Compiling .pio/build/normal_ESP8266_4M1M/libb59/SD_ID161/SD.cpp.o
Compiling .pio/build/normal_ESP8266_4M1M/libb59/SD_ID161/utility/Sd2Card.cpp.o
Compiling .pio/build/normal_ESP8266_4M1M/libb59/SD_ID161/utility/SdFile.cpp.o
Compiling .pio/build/normal_ESP8266_4M1M/libb59/SD_ID161/utility/SdVolume.cpp.o
In file included from .pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2Card.h:26:0,
from .pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/SdFat.h:29,
from .pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/SdFile.cpp:20:
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2PinMap.h:371:2: error: #error Architecture or board not supported.
from .pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/SdVolume.cpp:20:
from .pio/libdeps/normal_ESP8266_4M1M/SD_ID161/SD.h:25,
from .pio/libdeps/normal_ESP8266_4M1M/SD_ID161/File.cpp:15:
In file included from .pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/SdFat.h:29:0,
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2Card.h:65:37: error: 'SS_PIN' was not declared in this scope
uint8_t const SD_CHIP_SELECT_PIN = SS_PIN;
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2Card.h:68:31: error: 'MOSI_PIN' was not declared in this scope
uint8_t const SPI_MOSI_PIN = MOSI_PIN;
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2Card.h:70:31: error: 'MISO_PIN' was not declared in this scope
uint8_t const SPI_MISO_PIN = MISO_PIN;
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2Card.h:72:30: error: 'SCK_PIN' was not declared in this scope
uint8_t const SPI_SCK_PIN = SCK_PIN;
from .pio/libdeps/normal_ESP8266_4M1M/SD_ID161/SD.cpp:53:
from .pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2Card.cpp:26:
Compiling .pio/build/normal_ESP8266_4M1M/libe03/esp8266-oled-ssd1306/OLEDDisplayUi.cpp.o
Compiling .pio/build/normal_ESP8266_4M1M/libaf8/ccronexpr/ccronexpr.c.o
Compiling .pio/build/normal_ESP8266_4M1M/lib241/AM2320/AM2320.cpp.o
Compiling .pio/build/normal_ESP8266_4M1M/libb08/Adafruit_MPR121/Adafruit_MPR121.cpp.o
Compiling .pio/build/normal_ESP8266_4M1M/lib317/Adafruit_Motor_Shield_V2/Adafruit_MotorShield.cpp.o
Compiling .pio/build/normal_ESP8266_4M1M/lib317/Adafruit_Motor_Shield_V2/utility/Adafruit_MS_PWMServoDriver.cpp.o
Compiling .pio/build/normal_ESP8266_4M1M/libf92/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp.o
*** [.pio/build/normal_ESP8266_4M1M/libb59/SD_ID161/utility/SdVolume.cpp.o] Error 1
*** [.pio/build/normal_ESP8266_4M1M/libb59/SD_ID161/SD.cpp.o] Error 1
In file included from .pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2Card.cpp:26:0:
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2Card.cpp: In member function 'uint8_t Sd2Card::init(uint8_t, uint8_t, int8_t, int8_t, int8_t)':
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2Card.cpp:302:17: error: cannot convert 'volatile uint32_t* {aka volatile unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
clkport = portOutputRegister(digitalPinToPort(clockPin_));
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2Card.cpp:304:17: error: cannot convert 'volatile uint32_t* {aka volatile unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
mosiport = portOutputRegister(digitalPinToPort(mosiPin_));
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2Card.cpp:306:17: error: cannot convert 'volatile uint32_t* {aka volatile unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
misoport = portInputRegister(digitalPinToPort(misoPin_));
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2Card.cpp: In member function 'uint8_t Sd2Card::readData(uint32_t, uint16_t, uint16_t, uint8_t*)':
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/Sd2Card.cpp:438:12: warning: unused variable 'n' [-Wunused-variable]
uint16_t n;
*** [.pio/build/normal_ESP8266_4M1M/libb59/SD_ID161/utility/Sd2Card.cpp.o] Error 1
*** [.pio/build/normal_ESP8266_4M1M/libb59/SD_ID161/File.cpp.o] Error 1
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/SdFile.cpp: In static member function 'static uint8_t SdFile::make83Name(const char*, uint8_t*)':
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/SdFile.cpp:261:15: warning: unused variable 'b' [-Wunused-variable]
uint8_t b;
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/SdFile.cpp: In member function 'uint8_t SdFile::rmRfStar()':
.pio/libdeps/normal_ESP8266_4M1M/SD_ID161/utility/SdFile.cpp:907:40: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (curPosition_ != (32*(index + 1))) {
*** [.pio/build/normal_ESP8266_4M1M/libb59/SD_ID161/utility/SdFile.cpp.o] Error 1
============================================ [FAILED] Took 2.90 seconds ============================================
Environment Status Duration
custom_ESP8266_4M1M IGNORED
custom_sdk3_ESP8266_4M1M IGNORED
custom_beta_ESP8266_4M1M IGNORED
custom_ESP8266_4M2M IGNORED
normal_ESP8266_1M IGNORED
normal_sdk3_ESP8266_1M IGNORED
normal_ESP8266_1M_VCC IGNORED
normal_ESP8285_1M IGNORED
normal_WROOM02_2M IGNORED
normal_WROOM02_2M256 IGNORED
normal_ESP8266_4M1M FAILED 00:00:02.904
normal_ESP8266_16M IGNORED
minimal_core_242_ESP8266_1M_OTA IGNORED
minimal_core_242_ESP8285_1M_OTA IGNORED
minimal_core_261_ESP8266_1M_OTA IGNORED
minimal_core_261_ESP8285_1M_OTA IGNORED
minimal_core_261_sdk3_ESP8266_1M_OTA IGNORED
minimal_core_261_sdk3_ESP8285_1M_OTA IGNORED
minimal_IRext_ESP8266_1M IGNORED
minimal_IRext_ESP8266_4M1M IGNORED
minimal_IRext_ESP8266_4M2M IGNORED
normal_IRext_no_rx_ESP8266_4M2M IGNORED
test_ESP8266_4M_VCC IGNORED
test_beta_ESP8266_4M1M IGNORED
test_beta_ESP8266_16M IGNORED
dev_ESP8266_4M1M IGNORED
hard_SONOFF_POW_4M1M IGNORED
hard_other_POW_ESP8285_1M IGNORED
hard_Shelly_1_2M256 IGNORED
hard_Ventus_W266 IGNORED
custom_ESP32_4M316k IGNORED
test_ESP32_4M316k IGNORED
test_ESP32-wrover-kit_4M316k IGNORED
spec_debug_custom_ESP8266_4M1M IGNORED
spec_debug_beta_custom_ESP8266_4M1M IGNORED
spec_debug_custom_ESP32_4M316k IGNORED
spec_memanalyze_ESP8266 IGNORED
======================================= 1 failed, 0 succeeded in 00:00:02.904 =======================================
The terminal process terminated with exit code: 1
