Dear all,
I did make the pulse sensor working.. https://www.letscontrolit.com/wiki/index.php/TCR5000
Only now i do have servel fake pulses.
Is ther perhaps a solution to make the puls sensor stable?
Fake pulse TCR5000
Re: Fake pulse TCR5000
Depends on if you have set the sensitivity on the board and what else is effecting the measurements? Hard to tell.
i play with the senstive....
Only no differents
my settings: Perhaps there something need to change??
Only no differents
You have chosen the GPIO-1 (TX) which might be used?
https://www.letscontrolit.com/wiki/inde ... figuration
mmm should that be the problem....
Grr
Is it possible better to set a dallas to one of these pins?
This sensor perhaps have les problems withgpio 1 and 3?
Grr
If you turn off the serial communication in the advanced settings page it should work better.
