What are the factors that affect speed?
Forum rules
Ive switched my setup over to ESP Easy V 2.0 and it seems to be a lot slower than the old ESP easy.
Im running a few timers controlling a few relays and the page loads are unbareable.
I have 12 devices but only 6 are enabled.
A 3 second relay timer actually is taking 6 seconds.
Any suggestions on how to get this to run quicker?
Re: What are the factors that affect speed?
Maybe you suffer from the same bug as Shardan and myself (in controller/webserver). Psy0rz fixed it and published a new binary. Try to flash the new bin (still dev7) and see if the problem persistsHumanoidx wrote: ↑25 Apr 2017, 08:43 Ive switched my setup over to ESP Easy V 2.0 and it seems to be a lot slower than the old ESP easy.
toffel969 wrote: ↑25 Apr 2017, 17:10Maybe you suffer from the same bug as Shardan and myself (in controller/webserver). Psy0rz fixed it and published a new binary. Try to flash the new bin (dev8) and see if the problem persistsHumanoidx wrote: ↑25 Apr 2017, 08:43 Ive switched my setup over to ESP Easy V 2.0 and it seems to be a lot slower than the old ESP easy.
can you tell us how much available memory it says you have on the info page?
also i just commited a memory related bugfix, maybe you could try that one. a zipfile of the latest commit is always here: https://github.com/letscontrolit/ESPEas ... e/mega.zip
Hey guys I've tried this again with dev 11 and im still having issues. I'm using this to control my hydroponocs setup
Running a total of 8 timers that are used to control the on /off times of 4 relays. These timer values are saved by using 2 dummy devices, which allows me to change the on/off schedule for day and night.
In addition there are a few other temperatures and gpio that im reading. In total I'm using 12 devices.
- the thing runs ok if I set the controller to standalone only but if I set it to http domotics it freezes up.
Am I at the limits of the processing power of the esp8266 or is this a bug?
Also why does it show 35 devices on the main page if I'm only using 12?
Heres my code
And here are my devices
Heres my code
on system enable#status=1 do
Timerset,1,10
Timerset,3,20
Timerset,5,30
Timerset,7,10
TaskValueSet 9,1,3
TaskValueSet 9,2,237
TaskValueSet 9,3,2
TaskValueSet 9,4,238
TaskValueSet 10,1,2
TaskValueSet 10,2,298
TaskValueSet 10,3,70
TaskValueSet 10,4,7200
on system enable#status=0 do
gpio,5,1
gpio,4,1
gpio,0,1
gpio,2,1
on rules#timer=1 do
if [system enable#status]=1
gpio,5,0
timerset,2,[Timer1#SprayON1]
on rules#timer=2 do
gpio,5,1
timerset,1,[Timer1#SprayOFF1]
on rules#timer=3 do
gpio,4,0
timerset,4,[Timer1#SprayON2]
on rules#timer=4 do
If [system enable#status]=1
gpio,4,1
timerset 3,[Timer1#SprayOFF2]
on rules#timer=5 do
gpio,0,0
timerset,6,[Timer2#SprayON3]
on rules#timer=6 do
gpio,0,1
timerset,5,[Timer2#SprayOFF3]
on rules#timer=7 do
gpio,2,1
timerset,8,[Timer2#PumpOFF]
on rules#timer=8 do
gpio,2,0
timerset,7,[Timer2#PumpON]
On Pump#Status=1 do
TaskValueSet 12,1,0
TaskValueSet 12,2,0
TaskValueSet 12,3,0
TaskValueSet 12,4,[LOG#Pcount]+1
On top solenoid#status=1 do
TaskValueSet 12,1,[LOG#S1Count]+1
On Middle solenoid#status=1 do
TaskValueSet 12,2,[LOG#S2Count]+1
On Bottom solenoid#status=1 do
TaskValueSet 12,3,[LOG#S3Count]+1
On Clock#Time=All,12:00 do
TaskValueSet 9,1,5
TaskValueSet 9,2,595
TaskValueSet 9,3,5
TaskValueSet 9,4,595
TaskValueSet 10,1,5
TaskValueSet 10,2,595
TaskValueSet 10,3,80
TaskValueSet 10,4,14400
On Clock#Time=All,20:00 do
TaskValueSet 9,1,3
TaskValueSet 9,3,2
TaskValueSet 10,1,2
First impression:
Task 8 has no valid port (DS18B20 Id)
That causes some delay at least
Even if the device is not enabled?
Also heres the memory from the info page.
Any thoughts on the 35 devices?
Flash Size: 4096 kB
Flash Writes (since boot): 6
Sketch Size/Free: 421 kB / 600 kB
Free Mem: 26800
Devices: 35
Flash Size: 4096 kB
Free Mem: 26800
Devices: 35
Devices is a misleading wording, it is the number of PLUGINs that are in the firmware. If you would flash the unit with some other version the number would be different.
On my 2.0.0-dev7[normal] I have 44 "devices".
@HumanoidxEven if the device is not enabled?
What version are you running?
Release v2.0.0-dev11 shows "Enabled" in the GUI and looks like this
