Had this issue for some time now on my Nodo RFLink Gateway and cannot figure it out. Have tried extending USB cable + ferrite clamp and move it away from any other electrical source. Added 47uF reservoir capacityor on the Aurel 433Mhz VCC pin. External 7dBi antenna. RFLink will decode messages normally and suddenly only FineOffset messages is printed. The only way to recover is to manually powercycle the Mega board, SW reset does not help. I have ordered a second RFLink board to compare with.
I'm thinking about capturing a logictrace, is there any pins the Stuntteam is interested in?
RFLink stops decoding anything except FineOffset.
Re: RFLink stops decoding anything except FineOffset.
I guess it would be sufficient to make a debug log covering this change of decoding.
Unfortunately nothing is printed when trying to receive other protocols suchas, Kaku, NewKaku, Conrad, Kingpin, BofuMotor.
The debug output is from the FineOffset sensors
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R45;
20;01;FineOffset;ID=0087;TEMP=00cb;HUM=35;
20;02;FineOffset;ID=0088;TEMP=0057;
20;03;FineOffset;ID=00a7;TEMP=00ce;HUM=37;
20;04;FineOffset;ID=00a8;TEMP=0053;
20;05;RFDEBUG=ON;
20;06;DEBUG;Pulses=98;Pulses(uSec)=510,930,330,930,330,930,330,930,330,930,330,960,330,930,330,930,330,930,1320,930,330,930,1290,960,1290,930,330,960,1290,930,1290,960,330,960,1290,930,330,930,330,930,330,930,330,960,1290,930,1320,930,1290,960,330,930,330,930,330,930,1290,960,1290,930,330,960,330,930,330,960,330,930,330,930,330,930,330,930,330,930,330,930,330,930,330,930,1290,930,330,930,330,930,1320,930,330,930,330,930,330,930,1290,6990;
20;07;FineOffset;ID=0097;TEMP=80e7;
20;08;DEBUG;Pulses=98;Pulses(uSec)=540,900,360,900,360,900,360,900,360,900,360,900,360,900,360,900,360,900,1350,900,360,930,1320,930,1350,900,360,930,1350,900,360,900,360,900,1320,930,360,900,360,900,360,900,1350,900,1320,900,1350,900,1350,900,360,900,360,900,360,930,1320,900,1350,900,360,900,360,930,360,900,1320,930,1350,900,1320,900,360,900,360,900,1350,930,1320,900,360,900,1350,900,360,900,1350,900,360,900,360,900,360,930,1320,930,1320,6990;
20;09;FineOffset;ID=00b7;TEMP=00e7;HUM=25;
///Redferne
Reason found: Crappy Chinese Antenna.
///Redferne
