How can I manually create a switch in Domoticz for use with RFLink
bluejedi
#1 Post by bluejedi » 16 Nov 2016, 03:09
I want to manually add switch devices in Domoticz for use with RFLink (without the 'learn option').
When selecting Manual Light/Switch then under 'Type' I see no familiar type for RFLink or the 'FA500' protocol (ProMax on/off switches from Dutch Action shops) that I want to use.
The same dialog shows a setting for 'House Code', what is 'House Code'?
How can I manually add these switches?
dstewart275
Re: How can I manually create a switch in Domoticz for use with RFLink
#2 Post by dstewart275 » 22 Nov 2016, 08:35
There's an example of this on the FAQs ( http://www.nemcon.nl/blog2/faq ) for a Kaku switch
20;0D;Kaku;ID=41;SWITCH=2;CMD=ON;
The protocol for other switch types is also available here
http://www.nemcon.nl/blog2/protref
data
#3 Post by data » 05 Jan 2017, 15:06
Maybe my issue is related:
By issuing the command 10;Kaku;F;F;ON I can turn on my socket. However, it does not get properly recognized in the devices list.
Instead it shows up as ELRO AB400 (with different unit no. and id.) and does not work.
How can I create a generic Kaku Protocol switch?
Stuntteam
Site Beheer
#4 Post by Stuntteam » 05 Jan 2017, 15:21
check pm first.. that is a better way to get it fixed.
