Good morning,
First of all, I wish you the best for this year 2024.
I am very happy to see that a new version was released at the end of 2023 and in addition to integrate a function that I was waiting for a lot: the integration of Delta Dore devices.
However, I have some questions regarding these devices. (I am attaching 2 photos to be sure we are talking about the same ones)
I currently use 2 zones to control my radiators from thermostat 8.33. I managed to recover the frames for controlling the receivers:
-20;8D;X2D;ID=0000185f;SWITCH=05;CMD=ON;EXT=Deltia103;BAT=OK; : for zone 1
-20;8E;X2D;ID=1000185f;SWITCH=05;CMD=ON;EXT=Deltia103;BAT=OK; : for zone 2
I use the command: 10;X2D;1000185f;05;ON; to turn on zone 1, which works perfectly. However, on the thermostat the zone does not appear as ON (I still have the crescent moon)
How can I make commands executed from RFLink appear on the physical thermostat?
Also, I was not able to communicate directly with the 1.03 receiver, is there a little documentation on the procedure to follow?
Thanking you in advance.
thank you for your work
P.S: Sorry for my English, I'm French and I used Google translate
Deltia 8.33 and Deltia 1.03
- Deltia 8.33.jpg (747.43 KiB) Viewed 8741 times
- Deltia 1.03.jpg (558.34 KiB) Viewed 8741 times
Re: Deltia 8.33 and Deltia 1.03
For the issue with the thermostat not reflecting the status correctly, it might be related to how the thermostat interprets or updates its status based on received commands.
For the thermostat, the "sun" and "moon" logos are simply controlled by pressing the thermostat itself.
If I press the zone 2 button while it is in "moon" mode, it sends the ON command to the zone 2 receivers and the logo changes to "sun". And vice versa
For the moment I cannot receive a signal directly from the receivers. I thought I could do it because I saw in the changelog: "New Device: Deltia 1.03 - 3 zone - X2D (including support for pairing/association)" but I can't do it. Maybe I'm doing it wrong.
For the moment I can control my heaters with the rflink only by zone and they must first be added to the thermostat
