Deltia 8.33 and Deltia 1.03
Posted: 12 Jan 2024, 03:47
Good morning,
First of all, I wish you the best for this year 2024.
I am very happy to see that a new version was released at the end of 2023 and in addition to integrate a function that I was waiting for a lot: the integration of Delta Dore devices.
However, I have some questions regarding these devices. (I am attaching 2 photos to be sure we are talking about the same ones)
I currently use 2 zones to control my radiators from thermostat 8.33. I managed to recover the frames for controlling the receivers:
-20;8D;X2D;ID=0000185f;SWITCH=05;CMD=ON;EXT=Deltia103;BAT=OK; : for zone 1
-20;8E;X2D;ID=1000185f;SWITCH=05;CMD=ON;EXT=Deltia103;BAT=OK; : for zone 2
I use the command: 10;X2D;1000185f;05;ON; to turn on zone 1, which works perfectly. However, on the thermostat the zone does not appear as ON (I still have the crescent moon)
How can I make commands executed from RFLink appear on the physical thermostat?
Also, I was not able to communicate directly with the 1.03 receiver, is there a little documentation on the procedure to follow?
Thanking you in advance.
thank you for your work
P.S: Sorry for my English, I'm French and I used Google translate
