E-Ink display
mra2ko
E-Ink display
#1 Post by mra2ko » 18 Dec 2023, 11:24
anybody who make something with Good Display GDEY073D46 and similar E-Ink 7.3" and similar?
Or, it is possible use ?
Thank
Re: E-Ink display
#2 Post by Ath » 18 Dec 2023, 11:58
Your question is very similar to this one: https://letscontrolit.com/forum/viewtop ... 213#p67018 so my answer would be a copy of that ;)
bidrohini
Re: E-Ink display
#3 Post by bidrohini » 18 Dec 2023, 13:11
Here you will find Plugin details of the ILI9341, ILI9342, ILI9481, ILI9486 and ILI9488 chip families in case you decide to use these displays instead.
https://espeasy.readthedocs.io/en/lates ... /P095.html
mra2ko
Re: E-Ink display
#4 Post by mra2ko » 18 Dec 2023, 22:27
Thank to info !
bidrohini
Re: E-Ink display
#5 Post by bidrohini » 23 Dec 2023, 17:24
Ath wrote: 18 Dec 2023, 11:58 Your question is very similar to this one: https://letscontrolit.com/forum/viewtop ... 213#p67018 so my answer would be a copy of that ;)
Is the 2.9 Inch e-paper display with screen resolution of 296x128 pixels shown here supported by ESPeasy?
https://www.pcbway.com/project/sharepro ... 75f9a.html
Re: E-Ink display
#6 Post by Ath » 23 Dec 2023, 21:02
That resolution isn't in the current code, nor in PR #4223, and as I've written before, these controllers are 'poorly' documented (read: no documentation available, at all) to say the least, so don't expect that to work with ESPEasy.
mra2ko
Re: E-Ink display
#7 Post by mra2ko » 15 Jan 2024, 11:23
Thank to reply, i have other solution, I post it later...
