rules: send a message to an external web address
I want to send an external http command in Rules:
Example:
http://api.telegram.org/bot999:9999/sen ... t=TEST0815
PostToHTTP ?
SendToHTTP ?
PutToHTTP ?
I've googled a lot but can't find it. As far as I understand, https doesn't work.
But http to an address on the web should work.
How exactly do I have to split it up so that the message gets out?
Thanks for help!
Example:
PostToHTTP ?
SendToHTTP ?
PutToHTTP ?
Thanks for help!
Re: rules: send a message to an external web address
For telegram you´ll need a workaround...
see here: viewtopic.php?p=51745&hilit=telegram#p51745
For simple notifications i recommend ntfy.
There you can use PostToHTTP:
Example:
The problem with telegram is the S in HTTPS.
Not supported by ESPEasy yet...
PostToHTTP,ntfy.sh,80,/<Topic>,'title:<some_title>','<some_data>'
PostToHTTP,ntfy.sh,80,/Mytopic,'title:%sysname%','%eventvalue1%,%eventvalue2%,%eventvalue3%,%eventvalue4%'
I did not know. Even though I haven't worked with ThingSpeak yet, I'll try it.
As a beginner, I find it really unfortunate that https is not supported. With an ESP32 it shouldn't be a problem. This would be a great way to use data from the web (including weather data, etc.). But ok, I don't have enough knowledge.
In my opinion, Telegram would http command is enough (without s).
Maybe the easiest thing is to run another ESP that does this (without ESP Easy).
ESP easy -> ESP - > https -> Telegram, google sheets or....
Actually, I just want to have values from the Internet as variables in ESP Easy, which I can display on a TFT screen.
With the current task I would like to encourage the other side to start a google script, which sends the data to the ESP Easy.
I still need to learn more to understand it. Thanks for the support!
for getting data from openweather or thingspeak i can provide you with an custom build of espeasy...
see also here: https://github.com/letscontrolit/ESPEasy/pull/4856
Thanks for your support!
Why can you send to "thinkspeak" but not to http telegram directly (not s).
Or did I not understand it correctly?
There is only https for telegram....
If you past the link you posted into a browser you´ll see, that it redirects to https....
As said before, HTTPS requires a secure connection, based on certificates, that require quite some resources on the client side (ESPEasy). That, combined with ESPEasy has proven to be unusable on an ESP8266, but will probably be feasible on an ESP32.
Work on secured connections is a work in progress, with the first part being MQTT with TLS (transport layer security) support in PR #3788, but there are still some stability issues with the used TLS libraries. Later, when this is more stable, also HTTPS, using the same TLS library, is planned to be supported.
oh, sorry,
You're right, even though I typed http, the browser turns it into https
mea culpa
mea culpa
ok, thanks.
Thank you again for your understanding of my questions.
Ath wrote: ↑13 Dec 2023, 22:26As said before, HTTPS requires a secure connection, based on certificates, that require quite some resources on the client side (ESPEasy). That, combined with ESPEasy has proven to be unusable on an ESP8266, but will probably be feasible on an ESP32.
Users browsing this forum: No registered users and 43 guests
