i am a Beginner.
How exactly do I have to proceed in steps to get variables from the json that is returned via a URL to be called (Http Get command)?
I would then like to display this on a TFT screen.
only for example:
https://api.coinlore.net/api/tickers/
---> json: "price_usd" from 01
Thank you for your help!
Ede
get variables from https api json
Re: get variables from https api json
Hi, welcome to this forum.
At this time there are a few blocking issues to implement your request:
- ESPEasy does not (yet) support HTTPS connections (because of the resources required vs. the limited resources available).
- The HTTP GET support does not return the data (request response) as that would often overwhelm the (smaller) ESP units, again, because of limited available resources. There has, however, been a recent somewhat custom implementation of getting a response from a weather service, but that is, as said above, limited to HTTP connections.
Thank you very much for the very quick answer!
I know that the esp8266 requires an additional library for https (with aduino IDE), but with an ESP32 you no longer need this.
That's why I thought it should work with ESP Easy with an ESP32.
I'm still at the beginning/beginner. But that really limits what I wanted to do.
Ath wrote: ↑12 Dec 2023, 17:04 Hi, welcome to this forum.
