MQTT for rules on INA219 gives an error
costo
#1 Post by costo » 07 Nov 2023, 01:25
I'm using firmware version mega-20231013 and have a INA219 connected.
I want to use MQTT and sent data to domoticz and only use one task, so I use rules.
If I use MQTT, I get Error: MQTT: Invalid/Unhandled data received! (Topic: domoticz/in, Message: ("idx":20x)
for all 3 devices
on INA219#V do
  Publish domoticz/in,{"idx":207,"nvalue":0,"svalue":"[INA219#V]"}
on INA219#A do
  Publish domoticz/in,{"idx":208,"nvalue":0,"svalue":"[INA219#A]"}
On INA219#W Do
  Publish domoticz/in,("idx":209,"nvalue":0,"svalue":"[INA219#W]")
If I use the HTTP method it works, no error and devices get updated.
on INA219#V do
  SendToHTTP 192.168.178.202,8080,/json.htm?type=command&param=udevice&idx=207&nvalue=0&svalue=[INA219#V]
on INA219#A do
  SendToHTTP 192.168.178.202,8080,/json.htm?type=command&param=udevice&idx=208&nvalue=0&svalue=[INA219#A]
on INA219#W do
  SendToHTTP 192.168.178.202,8080,/json.htm?type=command&param=udevice&idx=209&nvalue=0&svalue=[INA219#W]
What is wrong with the MQTT rule that I copied from the wiki tutorial on rules.
Andrew Mamohin
Re: MQTT for rules on INA219 gives an error
#2 Post by Andrew Mamohin » 07 Nov 2023, 05:18
May be:
Publish domoticz/in,'{"idx":207,"nvalue":0,"svalue":"[INA219#V]"}'
Andy.
#3 Post by TD-er » 07 Nov 2023, 08:59
Yep, you have comma's in your argument, which is a command argument separator.
So you must wrap the argument in quotes of a type which will not occur in your argument.
There are 3 types of quotes:
So you can pick a quote to wrap the argument which is not being used in the argument itself, as suggested by Andrew
costo
#4 Post by costo » 07 Nov 2023, 15:34
Thank you Andrew, your suggestion with the quotes did the trick.
Thank you TD-er for explaining this in detail.
I suggest this is to be changed in the example in the wiki over here:
https://www.letscontrolit.com/wiki/inde ... th_own_IDX
there are no quotes around the MQTT example, that's why it ended up in this post ;)
#5 Post by Ath » 07 Nov 2023, 16:11
costo wrote: 07 Nov 2023, 15:34 I suggest this is to be changed in the example in the wiki over here:
The Wiki is very outdated, more up to date documentation can be found in ReadTheDocs.
costo
#6 Post by costo » 07 Nov 2023, 21:48
Ath wrote: 07 Nov 2023, 16:11 The Wiki is very outdated, more up to date documentation can be found in ReadTheDocs.
When looking at: https://espeasy.readthedocs.io/en/lates ... Rules.html
I see under the sub: Custom reports to Domoticz with own IDX
MQTT
on INA219#Amps do
 Publish domoticz/in,{"idx":123456,"nvalue":0,"svalue":"%eventvalue1%"} //Own made up IDX 123456
on INA219#Watts do
 Publish domoticz/in,{"idx":654321,"nvalue":0,"svalue":"%eventvalue1%"} //Own made up IDX 654321
Also here no quotes around the argument.
For future reference , someone with editing rights, can change this ?
#7 Post by Ath » 07 Nov 2023, 23:03
I'll put that on my todo list, at some interval, a checkup on parts of the docs is needed indeed ;)
bidrohini
#8 Post by bidrohini » 09 Nov 2023, 14:59
costo wrote: 07 Nov 2023, 01:25
On INA219#W Do
endon[/code]
Looks like there is a typo here. The 'on' should be in lower case.
on INA219#W do
  Publish domoticz/in,{"idx":209,"nvalue":0,"svalue":"[INA219#W]"}
#9 Post by Ath » 09 Nov 2023, 15:26
bidrohini wrote: 09 Nov 2023, 14:59 Looks like there is a typo here. The 'on' should be in lower case.
No, that doesn't matter, the script statements are handled case-insensitive. You should have found that in your searches for this answer...
