like this? if so, it doesn't help. (No more controllers are defined, just rules and dummy deviceAth wrote: ↑05 Jan 2025, 13:22Not sure why you have your Dummy device connected to a remote unit (1)? Quite sure you didn't do that on purpose, as then the values will be transmitted from that unit if it's available in the P2P network. Set that option to 0 to have it work locally (as it was by default).
How to get weather on esp using API with key?
Re: How to get weather on esp using API with key?
- 3.png (38.46 KiB) Viewed 4782 times
Not sure why you deleted the Controller. Isn't that supposed to be used to send the data to? A Controller is something totally different from a Remote Unit. You only had to reset the Remote Unit to 0.
To start with a clean slate, you can delete the Dummy Device, and the re-create it, without setting the Remote Unit field, just to be sure it is set up correctly.
To avoid resetting the data and possibly running into a loop, the Dummy device should NOT be named OpenMeteo, as that event is hard-coded for this weather service, you can name it OpenMeteoData f.e.
The rule to set the values to the Dummy device is IMHO somewhat inefficient (not sure why the original author wrote it that way
An improved version could look like this:
By using the task- and value- names in the taskvalueset commands you can have the Dummy device in any task without having to update rules, or when moving to a different ESP that already has another sensor in task 1
On OpenMeteo Do // Handle response from OpenMeteo event, don't create any task named 'OpenMeteo' to avoid running into an endless loop!
TaskValueSet,OpenMeteoData,Temp,%eventvalue1% // Przypisz do Dummy Device (pole 1)
TaskValueSet,OpenMeteoData,Hum,%eventvalue2% // Przypisz do Dummy Device (pole 2)
TaskValueSet,OpenMeteoData,Baro,%eventvalue3% // Przypisz do Dummy Device (pole 3)
TaskValueSetAndRun,OpenMeteoData,UV,%eventvalue4% // Set UV value AND send to all connected Controllers
LogEntry,'Values : Temp=%eventvalue1% Hum=%eventvalue2% Baro=%eventvalue3% UV=%eventvalue4%'
Hm, this won't start on boot, as there's an 'endon' missing from the rules, and the timer can be run more efficient.cccp79 wrote: ↑05 Jan 2025, 12:55Code: Select all
On System#Boot do timerSet,1,60 On Rules#Timer=1 do timerSet,1,60 sendtohttp api.open-meteo.com,80,"/v1/forecast?latitude=55.192375&longitude=37.786879¤t=temperature_2m,relative_humidity_2m,apparent_temperature,precipitation,rain,snowfall,weather_code,cloud_cover,surface_pressure,wind_speed_10m,wind_direction_10m&wind_speed_unit=ms&timezone=Europe%2FMoscow&forecast_days=1" Endon ...
On System#Boot Do
LoopTimerSet,1,60 // Repeat this timer every 60 seconds
On Rules#Timer=1 Do
No. It's not work(
On System#Boot Do
On Rules#Timer=1 Do
On OpenMeteo Do
TaskValueSet 1,Outdoor,Temp,%eventvalue1%
TaskValueSet 1,Outdoor,Hum,%eventvalue2%
TaskValueSet 1,Outdoor,Baro,%eventvalue3%
TaskValueSet 1,Outdoor,UV,%eventvalue4%
- 5.png (158.49 KiB) Viewed 4765 times
- 4.png (91.59 KiB) Viewed 4765 times
Where did you compile this from? It seems to be an older version of openmeteo-reply. The latest one works as described in the post.
If you still want to use the older version (personally I wouldn't because all the data is combined into one event string. the new version splits this into current, hourly and daily) your rule block has to look like this:
On OpenMeteoReply Do // Handle response from OpenMeteo event, don't create any task named 'OpenMeteo' to avoid running into an endless loop!
Using an esp8266 or esp8285 should also work, check the log for stability. I have added a warning if the reply message gets too long, as this can lead to instability on your device.
Ah, you have to handle the event OpenMeteo#current:
Edit: This is tested using latest Github PR code
On OpenMeteo#current Do
access to the Open-Meteo resource is broken((
87302: EVENT: Rules#Timer=1,3
187311: ACT : sendtohttp api.open-meteo.com,80,'/v1/forecast?latitude=55.192375&longitude=37.786879¤t=temperature_2m,relative_hu
191374: EVENT: http#api.open-meteo.com=-1
Ah, I got the same response just now, but I assumed it was me requesting from a yet unknown location. Probably they are taking a coffee break or something similar.
They work strangely, I had the same thing two days ago and I decided that this was some kind of bug. Today, the requests went away all day before this time (It's a pity I didn't have time to try to achieve results (Tell me where to get the latest PR code from Git - I'm completely confused(
....Hallelujah!!! Works! Thanks a lot!!! So I have an update code?
On System#Boot Do
On Rules#Timer=1 Do
- 6.png (28.99 KiB) Viewed 4726 times
Ah, you're still running the older version, as Chromo23 already expected. Not sure if a newer build was already available that uses the new event names (OpenMeteo#current, OpenMeteo#hourly and OpenMeteo#daily).cccp79 wrote: ↑05 Jan 2025, 15:53 ....Hallelujah!!! Works! Thanks a lot!!! So I have an update code?
(I built mine from latest Github source)
Could you please share a link to latest Github source? I don't know Github well (Ath wrote: ↑05 Jan 2025, 16:34Ah, you're still running the older version, as Chromo23 already expected. Not sure if a newer build was already available that uses the new event names (OpenMeteo#current, OpenMeteo#hourly and OpenMeteo#daily).cccp79 wrote: ↑05 Jan 2025, 15:53 ....Hallelujah!!! Works! Thanks a lot!!! So I have an update code?
Thanks!!!
easyfetch & openmeteo is coolest things. Many thanks!@chromo23
One sensor, one device and 8 sensors data))) Wow)))
- 8.jpg (194.66 KiB) Viewed 4655 times
- 7.png (112.61 KiB) Viewed 4659 times
Thanks. I am glad to hear that it worked.
Here a little "rules hack" to grep all the OpenMeteo reply's with one rules block:
On OpenMeteo* Do
If {ord:%eventpar%} = 99 // the ordinal/integer value of the first character of current is 99
LogEntry,'%eventpar% 1: %eventvalue1% 2: %eventvalue2% 3: %eventvalue3%'
Elseif {ord:%eventpar%} = 104 // the ordinal/integer value of the first character of hourly is 104
Elseif {ord:%eventpar%} = 100 // the ordinal/integer value of the first character of daily is 100
Endif
Just for your information, there is an ESP32-C3 with exactly the same form factor as the ESP-01S you are using there.
That one does have 4M flash, and thus is much easier to update.
Or you can simply replace the flash chip on that ESP-01S board with some 4M version.
Can you tell me exactly what you need?
ESP8266 and/or ESP32C6? Both the same plugins?
Please list which ones you need?
Yes. of course I know these form factors. And I've already changed the memory to ESP-01(S). However, I want to test the old devices for simple and not so simple tasks with 1M on board.
I don't know much about memory usage, can you tell me if there is enough memory for such tasks or not?
managed to compile such an assembly. But I'm not sure if I did everything right(
- 14.png (59.98 KiB) Viewed 4629 times
- 13.png (59.09 KiB) Viewed 4629 times
- 12.png (45.54 KiB) Viewed 4629 times
- 11.png (70.76 KiB) Viewed 4629 times
Problem with 1M flash is that you really need to strip out anything you don't need and you also have a much smaller file system.
If you want to store the EasyFetch files and maybe some extras, you can easily run into issues where saving settings may fail at some point due to file system fragmentation.
Also you cannot perform OTA updates on 1M builds so you need to take out the module each time you want to update it.
Replacing the flash chip for a 4MB version, makes this a lot easier.
Thank you. Everything is accessible and understandable. I want to test the ultimate strength.TD-er wrote: ↑05 Jan 2025, 22:10 Problem with 1M flash is that you really need to strip out anything you don't need and you also have a much smaller file system.
4M flash - not soldered)
- 16.jpg (282.36 KiB) Viewed 4617 times
Make sure to flash a 4M1M build after soldering the 4M flash module to it.
And you can backup the current settings if you like.
They should be compatible. (when shared between ESP8266/ESP8285, not ESP8266 vs. ESP32)
Hello. The firmware for Wemos works perfectly. It turned out that I have several 2432s028r displays. They work with EspEasy on the 20241221 Display 4M firmware [ESP8266,ESP32,ESP32-S2/S3/C3] with the Display - TFT ILI934x/ILI948x display selection.
I kindly ask you to compile for these displays. I really want it.
Regards.
Ps.
This display is ideal for building a weather station using https://open-meteo.com/en/docs.
It has a very good integrated display that works perfectly with EspEasy
All you need is FIRMWARE @chromo23
for this display.
Here are the settings:
Regards.
Ps.
- spi2.jpg (26.81 KiB) Viewed 4458 times
- spi1.jpg (18.71 KiB) Viewed 4458 times
- spi.jpg (45.57 KiB) Viewed 4458 times
- PXL_20250106_065415350.jpg (198 KiB) Viewed 4458 times
- PXL_20250106_053639971.jpg (209.99 KiB) Viewed 4458 times
Ohh that's a nice font!
Do you have a link to that 3D printed enclosure?
There are tons of them on Thingverse
https://www.thingiverse.com/search?q=2432s028r&page=1
Please make firmware for this display with jsonparser.
What happened in new versions with Mqtt Import?
The Apply Filters option is missing which works for me in the older version. How can I use mqtt import when I want to retrieve data by IDX?
- mqtt_old.PNG (53.04 KiB) Viewed 4425 times
- mqtt_new.png (10.61 KiB) Viewed 4425 times
Might be that some features were turned off to make it all fit, but I guess Ton is the one who can answer the reasons about this change. (however he is occupied with his daytime job right now)
It's a bit strange because in all descriptions there is an option Apply Filter in Generic - MQTT Import
In my case there is only Apply mappings:
Like I said, Ton has been maintaining that plugin for the last few years, so if there have been any changes or built-choices, he is the one to know best.
With "all descriptions" I assume you mean the docs: https://espeasy.readthedocs.io/en/lates ... #p037-page
Ton is very keen on also updating the docs when making changes, so that should be in sync with the current implementation.
Still if there are features left out of some builds (though I don't know why it should on a "normal ESP32" build), then there might be features documented which you cannot see in your setup.
But like I said, Ton can tell you all about it.
Also your screenshot shows it is a build of 2022, so Ton may have renamed some labels/texts in the last 2 years...
There is no such user as Ton. Enter the exact name of his nicknameTD-er wrote: ↑06 Jan 2025, 11:59 Like I said, Ton has been maintaining that plugin for the last few years, so if there have been any changes or built-choices, he is the one to know best.
Ath at the forum here.
And tonhuisman at GitHub.
Since I do speak him daily via Signal, I just out of habbit wrote down his first name.
Will jsonparser be added to all builds someday?
This is a very useful feature
Respect to @chromo23
Actually respect to Ath and TD-er. I only contribute every now and then, but these two people maintain and keep improving ESPEasy every day. So big thanks and kudos to them! My work is just like adding a shelf here and there in an already very well equipped apartment
So big thanks to the whole team. I asked if jsonparser will be added to all EspEasy builds in the future. I think it's a great feature for ESP.chromo23 wrote: ↑06 Jan 2025, 20:35Actually respect to Ath and TD-er. I only contribute every now and then, but these two people maintain and keep improving ESPEasy every day. So big thanks and kudos to them! My work is just like adding a shelf here and there in an already very well equipped apartment![]()
Just as a general statement about new features;
- ESP8266 does have a 'feature freeze' in the sense that any new plugin or feature will not be included in the standard builds. You may be able to use it in a 'custom' build unless specifically excluded. (e.g. "Touch" is a feature not available on ESP8266 and only on some ESP32 variants and SSL will simply not work on ESP8266 due to RAM limitations)
- If a feature or plugin is not included in a specific build (e.g. "collection", "climate", "display", etc.) due to size restrictions, then it will likely not be added to those builds in the future.
- Builds for nodes with 8M or 16M flash, we have the "max" builds, which will contain "everything".
N.B. I am working on a 2-stage update option, which does free up enough space on 4M ESP32 boards so we can make "MAX" builds for all. (at least considering the build size of the current "max" builds)
Can you tell me if I'm doing this right? To compile the build for 1M with openmeteo. I'm only making changes to the Custom file.h and select the default environment in platformio.ini, then click build?
When building a Custom.h build, you must choose the desired hardware (ESP8266 1M, not ESP8266 4M1M in your case) with also Custom in the name.
Yes I know and do it.
Could you help me build with openmeteo and json a binary for 1M with the plugins and controllers selected here. My build is successful, but I can't see the network, I can't find the initial espeasy network. I do not know why(
- Custom (1).rar
- (8.95 KiB) Downloaded 23 times
You could set up your network credentials in the Custom.h file (better not share that version here), but you'll have to clear the entire flash before flashing that build, to have it use the Custom.h defaults. The ESP should use DHCP by default. If you have a serial connection available, you can use the Monitor item (2 items below the Build menu-item in VSCode) to get the serial log and terminal. When selecting that log window, you can type commands (no echo until you press Enter), and use the command ip to have the ip-address it got from DHCP, revealed.
If adding your WiFi credentials in Custom.h doesn't work as intended, you can also use these commands to set up WiFi:
After you issue the save command, the settings will be saved, and the wifi connection retried.
NB: You can't use backspace to correct any typos... just type the command correct, or retry if you make a typo
AFAICS, you have all the other settings as expected, including the Thingspeak, Open-meteo and JSON parsing features.
wifikey,<your-AP-name>
wifipass,<your-super-secret-wifi-password>
save
The problem actually came out of nothing. After I got the weather, I decided to give it to a friend. And couldn't reconnect the esp to another network (WIFI scan didn't give results(
Many, many thanks!
do not up AP mode((
the same thing happened when I compiled it myself from the current sourcecode(
serial port output
╜пМхeсИcN╚♥xт%Vaвe!МИЖН(ДaИг00:01:11.466 : (25360) Info : WD : Uptime 1 ConnectFailures 0 FreeMem 25496 WiFiStatus: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
00:01:20.225 : (25440) Info : WIFI : Disconnected! Reason: '(1) Unspecified'
00:01:20.427 : (25440) Info : WIFI : Disconnected! Reason: '(1) Unspecified'
00:01:20.529 : (25472) Info : Reset WiFi.
00:01:22.816 : (25376) Info : WIFI : Set WiFi to OFF
00:01:23.033 : (25536) Info : WIFI : Set WiFi to STA
00:01:41.459 : (25200) Info : WD : Uptime 2 ConnectFailures 0 FreeMem 25336 WiFiStatus: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
00:02:11.463 : (25200) Info : WD : Uptime 2 ConnectFailures 0 FreeMem 25336 WiFiStatus: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
Can you tell me if this should work between two Dummy devices? In order to transform the wind direction to the text.
On System#Boot Do
On Rules#Timer=1 Do
TaskValueSet,OpenMeteoDatabigVal?0000FF,Темп?°C,%eventvalue1%
TaskValueSet,OpenMeteoDatabigVal?0000FF,Ощущ?°C,%eventvalue3%
TaskValueSet,OpenMeteoDatabigVal?0000FF,Влажн?H,%eventvalue2%
TaskValueSetAndRun,OpenMeteoDatabigVal?0000FF,Давл?мм,%eventvalue9%*0.75
TaskValueSet,OpenMeteobigVal?0000FF,Дождь?H,%eventvalue5%*100
TaskValueSet,OpenMeteobigVal?0000FF,Снег?H,%eventvalue6%*100
TaskValueSet,OpenMeteobigVal?0000FF,Облачность?H,%eventvalue8%
TaskValueSetAndRun,OpenMeteobigVal?0000FF,Ветер,%eventvalue11%
LogEntry,'Values : Темп?°C=%eventvalue1% Ощущ?°C=%eventvalue3% Влажн?H=%eventvalue2% Давл?мм=%eventvalue9%'
LogEntry,'Values : Дождь?H=%eventvalue5% Снег?H=%eventvalue6% Облачность?H=%eventvalue8% Ветер=%eventvalue11%'
on Wind#Vet do
TaskValueSet,6,1,%conv_wind_dir%([OpenMeteobigVal?0000FF#Ветер])
- 18.png (131.12 KiB) Viewed 2298 times
Are the correct values shown in the log? If so, then for this situation the TaskValueSet commands should be used with task- and value-numbers instead of taskname/valuename because of the special characters used here, they get parsed before processing, so these may be replaced by some other characters
I used %c_w_dir% - getBearing
As I understand it, a string value cannot be output to Dummy in any way?
Is it possible to output a string variable without using a controller?
Log
On D2#WD do
TaskValueSet,7,1,%c_w_dir%([Weather#Wind])
Log
337459: EVENT: D2#WD=0.0
337479: ACT : TaskValueSet,7,1,NW
Where do you want to use this string?
Quite a lot of plugins, like display etc. do have commands to accept strings.
I'm experimenting with esp-01 with 1MB flash. And I want to understand which plugin can be used to output the wind direction as a string value to compile. I thought it was possible in Dummy. But it didn't work out. Ok, I'll try other methods)
