Orcon id
Posted: 29 Oct 2023, 19:32
I have an Orcon venting unit with a remote that uses 868Mz.
I have een wemos von Enri (https://enri.nl/pcb/?page=itho)
The unit works partly:
30495940: ITHO: Received from ID: 48,0,e9 ; raw cmd: 0
30498730: ITHO: Received from ID: 82,4,72 ; raw cmd: 0
30500715: ITHO: Received from ID: 61,42,d0 ; raw cmd: 0
30503495: ITHO: Received from ID: 76,86,db ; raw cmd: 6
30507484: ITHO: Received from ID: 5a,59,25 ; raw cmd: 0
30508647: ITHO: Received from ID: 77,66,e0 ; raw cmd: 0
The line that ends with cmd 6 is a send signal from the remote. It has always the same ID. The unit sends info back with every time another ID.
The info on the divice it not clear to me.
There are: Unit ID remote 1 til 3. The number entered her are shown in the log when the esp sends a command.
There is also Device ID byte 1 til 3 with the remark: Note: For Orcon: This is the destination ID a.k.a. the ID of the Ventilation unit.
What has to be filled in here?
What can be the cause for the randon Id numbers the the esp recieves?
If this does not work i will go for the solution off Ronald: https://vdbrink.github.io/esphome/orcon ... ation.html
best regards,
Har
best regards,
Har
