battery powered sensor
Posted: 23 Oct 2023, 09:11
by agroszer
I'm trying to get the best availability time for my battery powered sensor.
I'm good with power usage in deepsleep.
Will set static IP to reduce traffic and wake time.
What else can I do to reduce wake time (and power usage)?
Data submission is done with a rule:
"On MQTT#Connected Do //when the broker is connected
If [sleepenabled#State]=1
taskrun,1 // run and send to MQTT
taskrun,2 // run and send to MQTT
// deepsleep,300 //go to deepsleep
timerSet,1,1
EndIf
EndOn
On Rules#Timer=1 Do
EndOn
thank you
Re: battery powered sensor
Posted: 23 Oct 2023, 09:22
by agroszer
Another interesting question is, taskrun MQTT publish seems to run queued, if I do deepsleep right after taskrun nothing gets published.
Does publish also run queued or it waits and the next command is execute only on success?
I might do better with disabling report to controller on the device and doing:
taskrun,1 // run
publish homeassistant/esp_01_3/bojler/Temperature,[bojler#Temperature]
EndIf
EndOn
Posted: 23 Oct 2023, 10:15
by chromo23
agroszer wrote: ↑23 Oct 2023, 09:11
I can show you how my code works to reduce uptime when reading a sensor and sending its data to thingspeak.
Basically i wait for WiFi and sensordata to become available and send it to thingspeak.
I don't use the sleep options in the /config tab. I emulate therefore the "30seconds after reboot" behavior in rules
If the data is send successfully go to sleep immediately....
On System#Wake Do
LoopTimerSet_ms,1,100,50 //loop until wifi is connected and we got data from sensor
GPIO,12,1 //Turn on the sensor
TaskRun,1 // Update first sensor
On WiFi#Connected Do
Let,1,1
On sensor_extern#All Do
Let,2,1
On Rules#Timer=1 Do
If [var#1]=1 and [var#2]=1 //when wifi is connected and there are values from the sensor send data
SendToHTTP api.thingspeak.com,80,/update?api_key=XXXXXXXXXXXXX&field8=[batterie#Analog]&field4=[sensor_extern#Humidity]&field7=[sensor_extern#Pressure]&field3=[sensor_extern#Temperature]
TimerSet_ms,1,0
Let,1,0
Let,2,0
Elseif %eventvalue2%=50 //after 5sec go back to sleep
Event,sleep
Endif
On http#api.thingspeak.com=200 Do //when receiving the HTTP code 200 it basically means the sending was successful
Event,sleep
On sleep Do //after sending data either go to sleep or if power cycled wait 30sec
If [boot#isboot]=1
DeepSleep,1800 //comment this out to stop deepsleep
Else
TimerSet,2,30
TaskValueSet,boot,1,1 //this sets the first value of a dummy device called boot to 1
//it doesn´t survive a reboot and therefore becomes 0. so you have 30 seconds after a reboot to do changes
Endif
On Rules#Timer=2 Do
Event,sleep
Posted: 23 Oct 2023, 11:12
Apart from the rules, you may also want to look at the electronics.
Most voltage regulators used have a high quiescent current usage.
Meaning they even draw a few mA when not powering anything (or very little power demand)
Also you may want to put some FETs to be able to switch on/off some sensors and connect them to an ESP pin you then pull high on the hardware tab at boot.
Posted: 29 Oct 2023, 18:57
by agroszer
Yeah, I connected an ESP12F directly to 3xAA NiMH batteries. ESP is happy with the ~4.2V input. I have an SHT20, powered on demand with a FET (power pin is set with hardware/defaults) and a DS18b20 always powered it does not seem to consume much idle. Both devices do NOT publish data to the controller.
Current rule is below, I'll try to reduce TimerSet_ms,1,150 or get rid of it as next.
// failsafe:
// if no wifi or no mqtt or whatever go back to sleep after 30 secs
// 30 secs should be more than enough to connect and send via mqtt
On System#Boot Do
timerSet,1,30
taskrun,1 // just run do NOT send
taskrun,2 // just run do NOT send
EndOn
publish,homeassistant/esp_01_3/room/Temperature,[room#Temperature]
publish,homeassistant/esp_01_3/room/Humidity,[room#Humidity]
publish,homeassistant/esp_01_3/bojler/Temperature,[bojler#Temperature]
TimerSet_ms,1,150
EndIf
EndOn
On Rules#Timer=1 Do
EndIf
EndOn
