MQTT duplicated messages
agroszer
#1 Post by agroszer » 23 Oct 2023, 08:43
I'm getting here MQTT messages duplicated, like:
Topic: homeassistant/esp_01_3/bojler/Temperature
22
2023-10-23 08:28:22:807
Topic: homeassistant/esp_01_3/room/Temperature
22.2
2023-10-23 08:28:22:903
Topic: homeassistant/esp_01_3/room/Humidity
52
2023-10-23 08:28:23:006
22
2023-10-23 08:28:23:108
22.2
2023-10-23 08:28:23:209
52
2023-10-23 08:28:23:310
I'm building a battery powered sensor, so having the least communication and uptime would be great.
MQTT config as attached, sensor update interval is 9999 seconds.
I'm using a rule to measure, submit and sleep:
On MQTT#Connected Do //when the broker is connected
  If [sleepenabled#State]=1
    taskrun,1 // run and send to MQTT
    taskrun,2 // run and send to MQTT
    // deepsleep,300 //go to deepsleep
    timerSet,1,1
  EndIf
EndOn
On Rules#Timer=1 Do
EndOn
bidrohini
Re: MQTT duplicated messages
#2 Post by bidrohini » 07 Nov 2023, 13:26
9999 seconds interval is extremely long. The sensor may be retransmitting the same data before it goes into deep sleep. You can make this interval smaller to see if the duplication disappears.
#3 Post by TD-er » 07 Nov 2023, 16:26
@bidrohini
The Task interval in ESPEasy is used to schedule a new call to PLUGIN_READ.
However whenever the task is run by using the command "taskrun", the scheduler will schedule a new call to PLUGIN_READ again at that moment using the "Interval" setting.
Thus the interval of 9999 is perfectly fine as it will probably never automatically call PLUGIN_READ as it would have been called in the mean time via the "TaskRun" command via rules.
About the duplicated messages.
Does ESPEasy loose connection often?
Or maybe the MQTT broker does not acknowledge the published messages and the controller thus retries to send?
Maybe you can also set the nr. of retry attempts in the controller settings to 0?
