hi,
i would like to connect a VL53L0X distance sensor, but could not found it in the device list.
used firmware: ESP_Easy_mega_20230822_normal_ESP8266_4M1M Aug 22 2023
I found that it normally should be found like “Distance – VL53L0X [TESTING]” (screenshot devices attached).
to I have to adjust something in the settings?
distance sensor VL53L0X not shown under the device list
- 2023-09-27 15_38_42-Clipboard.jpg (61.96 KiB) Viewed 1091 times
Re: distance sensor VL53L0X not shown under the device list
That plugin P110 - Distance - VL53L0X (200 cm) is not included in the Normal build but in the Collection B builds, as can be found in the plugin overview: https://espeasy.readthedocs.io/en/lates ... lugin.html
You can upgrade via the Tools/Update Firmware button after extracting that .bin from the zip file, or by using the WebFlasher from https://td-er.nl/espeasy (when using the Chrome or Edge browser)
thank you - I will try this
that worked
thanks
thanks
