ESP32s2 servo SG90
Posted: 18 Sep 2023, 15:36
by bo2be
Has anybody succeeded to drive a servo SG90 with an ESP32S2 mini?
For the test, I compared with an ESP8266 D1 Mini clone and it works pretty well.
I tested with an ESP32s2 mini and obtained only a random short vibration.
Both test assemblies were commanded with http
http://192.168.1.XXX/control?cmd=Servo,1,15,YY
XXX is my local ip adress for the ESP and YY is an angle between 0 and 90.
SG90 orange wire is on pin 15.
I tested several SG90, several ESPS2 mini boards, several pins, several EspEasy releases with no different behaviour.
I also tested with rules commands without more success.
Current configuration:
ESPs2 mini
ESP Board Name: Espressif Generic ESP32-S2 USB CDC 4M Flash ESPEasy 1810k Code/OTA 316k FS
Binary Filename: ESP_Easy_mega_20230822_normal_ESP32s2_4M316k_CDC
ESP8266 D1 mini
ESP Board Name: Espressif Generic ESP8266 ESPEasy 4M Flash 1M FS
Binary Filename:⋄ ESP_Easy_mega_20230822_normal_ESP8266_4M1M
Thanks in advance for comments.
Re: ESP32s2 servo SG90
Posted: 18 Sep 2023, 18:56
by TD-er
I never tested it on an S2.
I will hook up one later this evening to see what the logic analyzer will report.
Posted: 18 Sep 2023, 23:49
by TD-er
Yep, confirmed.
The servo command does not work well on an ESP32-S2.
When you set it to any positive angle, only a single pulse is given. No idea if it is of correct length.
Angle set to 0 or negative will give a constant pulse @ 1 kHz with 74.02% duty cycle.
Will probably be fixed when I apply this fix:
https://github.com/RoboticsBrno/ServoESP32/pull/25
Working on it...
Posted: 19 Sep 2023, 00:17
by TD-er
Here is the fix:
https://github.com/letscontrolit/ESPEasy/pull/4807
Here will be the GitHub Actions build:
https://github.com/letscontrolit/ESPEas ... 6228585983
And here a zip with the ESP32-S2 normal build:
https://www.dropbox.com/scl/fi/nwl55eq8 ... e432n&dl=0
Both the OTA update file and the 'factory' bin file included for flashing via serial.
Posted: 19 Sep 2023, 00:28
by TD-er
Not sure though if the ESP32-S2 is the best choice for a servo.
ESP32 (classic) has 20 bit resolution, where the S2 only has 14 bit.
You only have a fraction of the full pulse width available, so I guess it will be roughly 9 - 10 bits left for the full range of the servo.
Posted: 19 Sep 2023, 10:46
by bo2be
Super! it works!
Thanks a lot TD-er for your tremendous job.
You are wright for the less precise driving of the S2 ESP32 vs ES32 classic but it suits me for my purpose.
I run around twenty ESP's mainly for temperature monitoring with Domoticz. I gradually swap from ESP8266 to ESP32 and mainly for S2 type with a better wifi sensibility. Last year, I started 2 beehives weight recording with EspEasy with very good results. Now, as we live in a chalet in the Alps mountain, we are visited, to our great regret, by mischievous mice. So I am manufacturing several mouse traps with a photocell which drives a door and send us a SMS and mail alert through EaspEasy. Then we can release them, with no kill, far from our house (but not so far from our neighbor's
). So I don't need a huge precision with the servo which has just to draw the small cable which unlock the mouse trap door closing.
Thanks again for your fast answer.
Posted: 19 Sep 2023, 10:59
by bidrohini
Thanks for the whole thread. I was planning to use the same servo with ESP.
Posted: 19 Sep 2023, 11:00
by bidrohini
bo2be wrote: ↑19 Sep 2023, 10:46
Super! it works!
By the way, is the woodwork also done by yourself?
Posted: 19 Sep 2023, 11:09
by TD-er
Hmm if you are switching to ESP32-S2 for better WiFi stability, then you may have to be very lucky in buying boards.
Especially the "Wemos D1 mini" like form factor with ESP32-S2 are truly bad at WiFi. (those purple ones with PCB copper trace antenna)
My personal favorite right now whenever I need a small unit with good WiFi is the XIAO ESP32-C3 board.
https://www.tinytronics.nl/shop/en/deve ... o-esp32-c3
It has a 'sticker antenna', which you can mount in just the orientation you need.
Posted: 19 Sep 2023, 15:03
by bo2be
Thanks for the advice and I will test one at least within some weeks.
You were wright, I am using purple board devices.
Sometimes, I even weld 3 m of RG316, to cross some huge walls
I didn't notice stability problem at my level of use which is not a reference.
If I notice something I will let you know.
For bidrohini , yes,it is home woodwork with old deck boards, not precisely cut, but it does the job!
Posted: 19 Sep 2023, 15:27
by TD-er
Problem with those purple ESP32-S2 boards is that the WiFi stability can suddenly change.
One time it is working perfectly well and the next moment it may suddenly loose several packets (e.g. when sending a continuous ping to the unit).
I have no idea what may be causing such behavior.
I also have some really old ESP32-S2 boards which are encapsulated in a separate shield on a PCB like those old ESP12-F modules on the early NodeMCU and Wemos D1 mini boards and those work very well.
So I guess it may have something to do with either proper impedance matching of the antenna, or maybe the shielding actually does help improving stability.
Posted: 19 Sep 2023, 18:21
by bo2be
For that purpose I will purchase an encapsulated ESP32-C3 board and a bare one. Just to see if I notice a difference.
Posted: 19 Sep 2023, 18:54
by TD-er
That "open" board in the first picture does have a ceramic antenna.
Those are often significantly better than PCB trace antennas.
Posted: 22 Sep 2023, 16:05
by bo2be
Mouse trap mass production is done with Esp32S2 driving the SG90 servo.
My cat can retired!
Posted: 22 Sep 2023, 16:45
by TD-er
Maybe you can send your cat to follow a course to become the mouse trap supervisor.
Perhaps at some point he/she can coordinate an entire crew of mouse-relocators to empty those traps.
