A02YYUW help needed
Posted: 12 Sep 2023, 21:23
I have installed ESP_Easy_mega_20230822_collection_A_ESP32_4M316k on a AZ-Delivery ESP32-WROOM-32
An A02YYUW is attached and I have been testing the plugin. A strange thing is happening.
The initial distance measurement is correct. However, regardless of changing the distances, all subsequent readings are exactly the same... no change.
The logs are below:
I have proven that the initial reading is correct by rebooting with a different distance. It is simply that no new readings are taken after this initial one and the same value is always returned. It is also in mm regardless of whether I divide by 10 (I want cm).
Any help appreciated
The logs are below:
209: ^^^INIT : Booting version: ESP_Easy_mega_20230822_collection_A_ESP32_4M316k, (GitHub Actions) mega-20230822 (ESP32 SDK 4.4.5.23
209: INIT : Free RAM:244296
211: INIT : Soft Reboot #2 Last Action before Reboot: Intended Reboot: CommandReboot Last systime: 146 - Restart Reason: CPU0: Softw
212: FS : Mounting...
239: FS : Mount successful, used 141815 bytes of 290156
256: CRC : Settings CRC ...OK
292: ESPEasy console using ESPEasySerial
307: CRC : SecuritySettings CRC ...OK
333: INIT : Check for Priority tasks
334: INIT : SPI not enabled
335: Set Network mode: WiFi
437: WIFI : Set WiFi to STA
539: WiFi : Event STA Started
640: WiFi : Start network scan channel 1
7055: WiFi : Scan finished, found: 13
7057: WiFi : Best AP candidate: BT-AAAAAA 99:99:99:99:99:99 Ch:1 (-55dBm) WPA2/PSK bgn
7058: WiFi : Added known candidate, try to connect
7059: WiFi : Best AP candidate: BT-AAAAAA 99:99:99:99:99:99 Ch:1 (-55dBm) WPA2/PSK bgn
7061: INIT : Free RAM:196972
7119: A02YYUW: Initialization OK
7123: INFO : Plugins: 83 [Normal][Collection_A ESP32] (ESP32 SDK 4.4.5.230614)
7125: WiFi : Best AP candidate: BT-AAAAAA 99:99:99:99:99:99 Ch:1 (-55dBm) WPA2/PSK bgn
7126: WIFI : Connecting BT-AAAAAA 99:99:99:99:99:99 Ch:1 (-55dBm) WPA2/PSK bgn attempt #0
7135: WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
8187: Webserver: start
8254: A02YYUW: Distance value = 72
8270: WIFI : Connected! AP: BT-AAAAAA (99:99:99:99:99:99) Ch: 1 Duration: 1137 ms
8271: WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: Conn.
8515: WIFI : DHCP IP: 192.168.9.99 (Collection-A-ESP32) GW: 192.168.9.999 SN: 255.255.255.0 DNS: 192.168.1.254 / 0.0.0.0 duration:
8523: UDP : Start listening on port 8266
8523: firstLoopConnectionsEstablished
8532: mDNS : Starting mDNS...
8536: mDNS : Started, with name: Collection-A-ESP32.local
8560: MQTT : Intentional reconnect
8586: MQTT : Connected to broker with client ID: Collection_A_ESP32_0
8592: Subscribed to: Collection_A ESP32/#
9672: static_file: /esp.css
9802: WD : Uptime 0 ConnectFailures 0 FreeMem 167708 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
17229: static_file: /esp.css
17230: Serve 304: 246899765 /esp.css
20232: static_file: /esp.css
20233: Serve 304: 246899765 /esp.css
39522: WD : Uptime 1 ConnectFailures 0 FreeMem 169980 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
67189: A02YYUW: Distance value = 72
69522: WD : Uptime 1 ConnectFailures 0 FreeMem 174872 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
99522: WD : Uptime 2 ConnectFailures 0 FreeMem 174896 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
127189: A02YYUW: Distance value = 72
129522: WD : Uptime 2 ConnectFailures 0 FreeMem 174896 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
159522: WD : Uptime 3 ConnectFailures 0 FreeMem 174896 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
187189: A02YYUW: Distance value = 72
