Rules If statment String
Posted: 30 Aug 2023, 10:05
by Sjuul
I'am busy to connect my airco to ESP-Easy receiving data string works great.
The mode of the airco is transferred in a string like "FAN"
Now I try to make in the rules of ESP-Easy an if statement with this string see the code below
If [Airco2#mode] = 'FAN'
SendToHTTP 192.168.1.100,8080,/json.htm?type=command¶m=switchlight&idx=384&switchcmd=Set%20Level&level=10
Endif
This doesn't work,
Has someone any suggestions to send the HTTP command when the "Fan" string is received?
Re: Rules If statment String
Posted: 30 Aug 2023, 10:11
by Ath
ESPEasy does not support processing string values in rules like that at this time.
How are you receiving those values?
Can they be replaced by numerical values on the sending side? As those can be handled by ESPEasy.
Posted: 30 Aug 2023, 11:57
by Sjuul
Below the string i recieved.
Airco2#settings=`{'roomTemperature':19.0,'wideVane':'<<','power':'OFF','mode':'FAN','fan':'1','vane':'1','iSee'
As you can see there are some numbers but not for everthing.
Posted: 30 Aug 2023, 12:09
by TD-er
How do you receive this string?
Via MQTT?
Posted: 30 Aug 2023, 13:09
by Sjuul
It comes from "HwSerial port 0" Port to GPIO1 and GPIO3
I use this plugin
https://espeasy.readthedocs.io/en/lates ... /P093.html
Posted: 30 Aug 2023, 14:46
by Ath
Well, you can use the substring function (
docs) and indexof function (just below the substring function in the docs) to find and extract the value, into another indexof to find some known values, and use that for comparisons, something like this:
(Be prepared that this isn't very efficient, of well designed yet, just dumping my brainfart
on airco2#settings=* do // use the asterisk to allow non-numeric 1st argument
let,1,{indexof:mode:"%eventvalue1%"} // Start position of word: mode
let,2,{indexof:FAN:{substring:%v1%+8:%v1%+11:%eventvalue1%}} // TODO: Check offsets
if %v2%>-1
Disclaimer: Air code, untested
Edit: Fix some typos
Posted: 30 Aug 2023, 16:08
by Sjuul
Thanks Ath,
This gives me an eye opener.
The plugin 0092 can give also sort value [Airco2#mode] returns only FAN
Just after the position you mentioned in the online help I found the function {equals:<string1>:<string2>}
If {equals:[Airco2#mode]:FAN} = 1
SendToHTTP 192.168.1.100,8080,/json.htm?type=command¶m=switchlight&idx=384&switchcmd=Set%20Level&level=10 //10 = Ventileren in Domoticz
Posted: 30 Aug 2023, 16:51
by Ath
Ah, yes, that's much easier. Don't have any experience with this plugin
though I have added that feature to get all values, and wrote the documentation (
here).
