SHT45 don't show the values in domoticz
Hi all,
I connected an SHT45 sensor at an Wemos D1 mini pro with firmware ESP_Easy_mega_20230822_climate_ESP8266_4M1M.
I2C address 0x44 (68) default
The temperature and humidity values are visible under devices in the sketch of the Wemos IP address. 26.3 and 48
In domoticz under Devices I see by data the next: 0, 26.3;48
Three values instead of two values. The first value 0 is wrong. 26.3 is temperature and 48 is the humidity.
In domoticz under tab Temperature I see only SHT45 without any values.
What goes wrong here?
Greetz,
Jack
Greetz,
Jack
Re: SHT45 don't show the values in domoticz
Looks like the sensor type of P153 should have been SENSOR_TYPE_TEMP_HUM
I think Ton is already working on a fix
Thanks for reporting this issue.
Please report your findings here or in Github, so we can resolve this.
TIA.
Yep, created PR #4779 to correct this error, can be tested once this GH Actions run is finished. (You'll need a free Github account to be able to download the binaries.)
TIA.
I will try when GH Actions run is finished. When is ready?
Jack
Jack
The runs usually take ~40 minutes, but if multiple are running in parallel, they usually wait for each other to complete the last step
It's available since a few minutes.
I download from github: ESPEasy-1-bugfix-P153-fix-wrong-sensor_vtype.zip
Where can I find the right binaire file?
You need to be logged in to your (free) Github account to be able to download binaries from an Actions run (link above), there you will find a .zip file per processor architecture we currently support, in the Artifacts section. After unpacking that .zip file you will find a bin folder, very similar to what's available from the Releases downloads. Just pick the same build type (Climate) and upload via the Tools page Firmware update button (leave some time to let it do some processing after uploading on an ESP8266, like at least 30 seconds before getting worried it failed ). All your settings/configuration will be preserved
Top!
Problem solved.
Now I see in domoticz under tab Temperature
the value for temperature en humidity
Very thanks!
Problem solved.
Very thanks!
Users browsing this forum: Semrush [Bot] and 39 guests
