ESP Easy Flasher - error: espcomm_upload_mem failed
masterds
#1 Post by masterds » 27 Jul 2023, 16:17
Hello everyone,
i try to flash an ESP32.
Unfortunately I get an error "error: espcomm_upload_mem failed".
This is the port of the logfile with the error.
 Uploading 1439296 bytes from C:\Users\denni\Documents\ESPEasy\bin\ESP_Easy_mega_20230623_normal_ESP32_4M316k.factory.bin to flash at 0x00000000
[27.07.2023 15:55:54] 	erasing flash
[27.07.2023 15:55:54] 	size: 15f640 address: 000000
[27.07.2023 15:55:54] 	first_sector_index: 0
[27.07.2023 15:55:54] 	total_sector_count: 352
[27.07.2023 15:55:54] 	head_sector_count: 16
[27.07.2023 15:55:54] 	adjusted_sector_count: 336
[27.07.2023 15:55:54] 	erase_size: 150000
[27.07.2023 15:55:54] 	espcomm_send_command: sending command header
[27.07.2023 15:55:54] 	espcomm_send_command: sending command payload
[27.07.2023 15:55:54] 	setting serial port timeouts to 15000 ms
[27.07.2023 15:55:54] 	read 0, requested 1
[27.07.2023 15:55:54] 	setting serial port timeouts to 1000 ms
[27.07.2023 15:55:54] warning: espcomm_send_command: didn't receive command response
[27.07.2023 15:55:54] warning: espcomm_send_command(FLASH_DOWNLOAD_BEGIN) failed
[27.07.2023 15:55:54] closing bootloader
[27.07.2023 15:55:54] 	flush start
[27.07.2023 15:55:54] 	setting serial port timeouts to 1 ms
[27.07.2023 15:55:54] 	flush complete
[27.07.2023 15:55:54] error: espcomm_upload_mem failed
[2023-07-27 15:55:54] DONE! BUT WITH (1) ERRORS!
Can anyone help?
I tried the reset and boot switch on the ESP - nothing works.
Screenshot of my flasher settings:
Re: ESP Easy Flasher - error: espcomm_upload_mem failed
#2 Post by Ath » 27 Jul 2023, 16:40
Please don't use the ESP Easy Flasher to flash ESP32 boards, that doesn't work at all.
Instead use the (also included) Espressif flash download tool. That tool won't allow to apply any settings though, you can set those either using a terminal program via USB-serial, or connect to the ESPEasy WiFi AP that is available after boot.
You did already chose a correct .factory.bin file, required for the initial upload, so that should get you a working device :)
#3 Post by TD-er » 27 Jul 2023, 17:35
You can also use the web flasher, which makes selecting a binary file a lot easier now we support so many variants of the ESP32:
https://td-er.nl/ESPEasy/
