When I see all my ESP in the main page, I have Age(s) at the end. If I change to the device that has Age 1, for example, it shows me a completely different value on the ESP page.
The load is the same, no matter from which ESP I look at, but the meaning of Age does not make sense to me if it is not the same for all of them.
Can someone explain this to me?
THX
EDSTOBI
Age(s) completely different value per esp
Re: Age(s) completely different value per esp
The age is the last time the other node was seen via p2p.
Typically each p2p node will report its presence every 30 seconds, so it will hardly every go over 30 seconds.
If it does, then it means the node was not seen, so either it is offline, or unable to reach the node you're looking at in your browser.
If the 'age' of a p2p node exceeds 600 sec (10 mins), it will be removed from the list of known p2p nodes.
Users browsing this forum: No registered users and 43 guests
