I used from time to time web flasher which url address is on
https://github.com/letscontrolit/ESPEasy
but when I try today:
https://td-er.nl/ESPEasy/
see on screen:
You don't have permission to access this resource.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
ESPEasy Web flasher
Re: ESPEasy Web flasher
Can you send me your IP-address via a direct message?
I have disabled a few IP-ranges (quite a few) due to massive hack attempts.
Just to give some indication, I get about 3.3 TByte a month in incommig traffic which is blocked by these filters (so no outgoing traffic) for hack-attempts.
So at some point I may have added blocks of IP-addresses which may be a bit too course and I'm happy to remove yours from that block.
Hi!
I have the same as the guy above. Can I ask you for help?
I have the same problem when trying to access https://td-er.nl/ESPEasy/
I am getting:
My IP is dynamic but it should be in range of 77.28.0.0/16
I am getting:
Cannot send you a DM because i do not have rights.Forbidden
Users browsing this forum: Bing [Bot] and 41 guests
