difference for rules notation in different esp versions
BartSr
#1 Post by BartSr » 21 Jun 2023, 11:49
I had working rulesset on ESP BinFile ESP_Easy_mega_20211224_normal_ESP8266_4M1M
Rules Set 1
on System#Boot do
  loopTimerSet,1,10
  loopTimerSet,2,2
on Rules#Timer=2 do
 if [Plugin#GPIO#Pinstate#14]=0 //D5
	sendto, 2, "gpio 16,1"
 if [Plugin#GPIO#Pinstate#14]=1
	sendto, 2, "gpio 16,0"
on Rules#Timer=1 do
  sendto,2,"timerset,1,10"
now I want to transfer this to other ESP
BinFile ESP_Easy_mega_20201227_normal_ESP8266_4M1M
But now there must be used other way of putting code in starting with Event Name
Can pls advise how to convert?
TIA
-Bart
Re: difference for rules notation in different esp versions
#2 Post by TD-er » 21 Jun 2023, 12:07
You are moving rules from a newer ESPEasy version to an older one.
I suspected the looptimer wasn't available in that older build, but apparently it was
See: https://espeasy.readthedocs.io/en/lates ... oop-timers
So the only thing I can think of here is to format the rules a bit to remove extra spaces in command parsing and put the first line in a comment:
// Rules Set 1
on System#Boot do
  loopTimerSet,1,10
  loopTimerSet,2,2
on Rules#Timer=2 do
    sendto,2,"gpio 16,1"
    sendto,2,"gpio 16,0"
on Rules#Timer=1 do
Users browsing this forum: Ahrefs [Bot] and 6 guests
