control a somfy remote with ESPEasy - switch issues
Posted: 19 Jun 2023, 21:49
I bought a somfy situo io remote and soldered to D5/6/7 the switches of the remote as well as VCC and GND.
(similar to this https://www.hackster.io/beejayf/somfyduino-io-3d8283)
I added 3 switch input devices with these settings:
when I am sending this command:
http://192.168.100.206/control?cmd=Pulse,14,1,500 --> the blind is moving down
BUT
if I am using these
http://192.168.100.206/control?cmd=Pulse,12,1,500
http://192.168.100.206/control?cmd=Pulse,13,1,500
nothing happens
I double checked wireing and soldering it is OK.
Does anyone see a mistake in my settings?
Do I need the devices if I want to control it later by mqtt?
my firmware Build: ESP_Easy_mega_20230409_normal_ESP8266_4M1M Apr 9 2023
Device: Switch input - Switch
Enabled: X
Internal PullUp:- X
Inversed Logic:
GPIO ⇄ 14 / 13 or 12
Switch Type: Switch
Switch Button Type: Normal Switch
Send Boot state:
Send to Controller X
Interval: 0 [sec]
BUT
if I am using these
nothing happens
