ATLANTIC MD 210R
Post here about devices that are not yet or not fully supported
Jean-Nicolas
ATLANTIC MD 210R
#1 Post by Jean-Nicolas » 10 Jun 2023, 15:54
I have several MD 210R 433Mhz door detector working correctly with my RF-LINK.
The new detectors with the same reference bought recently on AliExpress are no more recognised.
The new ones are marked "ASK 433" the old ones where not (just the serial number)
And the new ones blink only once when switching as the old where blinking 3 times.
In debug mode I get This :
"ON"
20;41;DEBUG;Pulses=76;Pulses(uSec)=1380,3960,300,300,720,300,720,690,330,300,720,690,330,300,720,300,720,300,720,300,720,690,330,690,300,300,720,690,330,690,330,300,750,690,330,300,720,300,720,720,300,300,720,690,330,690,300,720,300,690,330,300,720,300,720,300,720,300,720,690,330,690,330,690,330,300,720,300,720,300,720,690,330,300,720,1290;
20;42;DEBUG;Pulses=174;Pulses(uSec)=750,270,690,300,690,660,300,660,300,660,300,270,690,270,690,300,690,690,330,300,720,1320,1290,3960,330,300,720,300,720,690,300,300,720,690,330,300,750,300,720,300,720,300,720,720,300,720,300,300,720,690,300,690,300,300,720,690,330,300,750,300,720,690,300,300,720,690,330,690,330,690,300,690,300,300,720,300,720,300,750,300,720,720,300,690,330,690,330,300,720,300,750,300,720,720,300,300,720,1320,1290,3960,300,300,720,300,720,720,300,300,720,690,330,300,720,300,720,300,720,300,720,690,300,720,330,300,750,720,300,690,300,300,720,690,330,300,750,300,720,690,300,300,720,690,330,690,330,690,300,690,300,300,720,300,720,300,720,300,720,720,300,690,300,690,330,300,720,300,750,300,720,690,300,300,720,6990;
"OFF"
20;43;DEBUG;Pulses=76;Pulses(uSec)=1380,3960,300,300,720,300,720,690,330,300,720,690,300,300,720,300,720,300,750,300,720,690,300,690,330,300,720,690,330,690,330,300,720,720,300,300,720,300,720,720,300,300,720,690,300,690,330,690,330,690,330,300,720,690,300,300,720,300,720,690,330,690,300,690,300,300,720,300,720,720,300,690,300,300,720,1320;
20;44;DEBUG;Pulses=174;Pulses(uSec)=390,270,690,270,690,690,270,660,270,660,300,300,690,270,690,660,300,690,330,300,720,1290,1290,3960,330,300,720,300,720,720,300,300,720,690,330,300,750,300,720,300,720,300,720,690,330,690,330,300,720,690,300,690,300,300,720,690,330,300,750,300,720,690,300,300,720,690,330,690,330,690,300,720,300,300,720,690,330,300,720,300,720,690,300,690,330,690,330,300,720,300,750,690,300,690,300,300,720,1320,1290,3960,300,300,750,300,720,690,300,300,720,690,330,300,720,300,720,300,720,300,720,690,330,690,330,300,720,720,300,720,300,300,720,720,300,300,750,300,720,690,300,300,720,690,330,690,330,690,300,690,300,300,720,690,330,300,720,300,750,690,300,690,300,690,330,300,720,300,720,720,300,720,300,300,720,6990;
Do you have any knowledge of the problem ?
I'm also looking for cheap 433 Mhz door contacts compatible with RF-Link if I can't have those working.
Thanks for your help
bidrohini
Re: ATLANTIC MD 210R
#2 Post by bidrohini » 13 Jun 2023, 18:24
I think the only way is to Capture the new detector's pulse patterns with an RF signal analyzer . Then compare it with the expected pattern.
Stuntteam
Site Beheer
#3 Post by Stuntteam » 14 Jun 2023, 11:17
We are looking into it..
OlivFromBreizh
#4 Post by OlivFromBreizh » 14 Jun 2023, 20:21
I have the same issue with clone of MD-210R (bought on Amazon).
I will be more than happy if you can identify the problem.
Stuntteam
Site Beheer
#5 Post by Stuntteam » 14 Jun 2023, 21:42
Mail me a debug log (or add it here) of your "amazon" MD210R version..
so we can check if it is exacly the same or needs some adaptation.
OlivFromBreizh
#6 Post by OlivFromBreizh » 15 Jun 2023, 09:57
In fact I already sent you the trace few months ago (by mail, february 14th) but I can add them here too.
I activated debug data using RFLink Loader, here are 3 data set for a single sensor (3 tests of open/close):
// Open the door #1
2023-02-06 13:15:09 - 20;97;DEBUG;Pulses=511;Pulses(uSec)=4560,930,1260,3960,270,330,690,720,270,750,270,330,690,720,270,330,690,330,690,330,690,720,270,330,690,720,270,720,270,330,690,330,690,720,270,720,270,720,300,330,690,720,270,330,690,330,690,720,300,720,300,720,270,330,690,720,300,330,690,330,720,720,270,720,270,720,300,330,690,330,690,330,720,330,690,720,270,1320,1260,3960,300,330,720,720,300,720,300,330,720,720,300,330,720,330,720,330,720,720,300,330,720,720,300,720,300,330,720,330,720,720,300,720,300,720,300,330,720,720,300,330,720,330,720,720,300,720,300,720,300,330,720,720,300,330,720,330,720,720,300,720,300,720,300,330,720,330,720,330,720,330,720,720,300,1320,1290,3960,300,330,720,720,300,720,300,300,720,720,300,330,720,330,720,330,720,720,300,300,720,720,300,720,300,330,720,330,720,720,300,720,300,720,300,330,720,720,300,300,720,300,720,720,300,720,300,720,300,330,720,720,300,300,720,330,720,720,300,720,300,720,300,300,720,300,720,330,720,330,720,720,300,1320,1290,3960,300,300,720,720,300,720,300,330,720,690,300,300,720,300,720,330,720,690,300,330,720,690,300,690,300,330,720,300,720,690,300,690,300,690,300,300,720,720,300,300,720,330,720,690,300,690,300,720,300,330,720,690,300,330,720,300,720,690,300,720,300,690,300,330,720,300,720,300,720,300,720,690,300,1320,1290,3930,300,300,720,690,300,690,300,300,720,690,300,300,720,300,720,300,720,720,300,300,720,690,300,690,300,300,720,300,720,720,300,690,300,690,300,300,720,690,300,300,720,300,720,690,300,690,300,690,300,300,720,720,300,330,720,300,720,690,300,690,300,720,300,330,720,300,720,330,720,300,720,720,300,1320,1290,3930,300,330,720,690,300,690,300,300,720,720,300,330,720,330,720,330,720,720,300,330,720,720,300,720,300,330,720,330,720,720,300,720,300,720,300,330,720,720,300,330,720,330,690,720,270,720,300,720,300,330,720,720,300,330,690,330,690,720,270,720,270,720,270,330,690,330,690,330,690,360,690,750,270,1350,1260,3990,270,330,690,750,270,750,270,360,660,750,270,360,660,360,660,360,660,750,240,360,660,780,240,780,240,390,660,390,630,780,210,780,240,780,210,390,630,780,210,390,630,390,630,780,210,780,210,780,210,390,630;
// Close the door #1
2023-02-06 13:15:11 - 20;98;DEBUG;Pulses=511;Pulses(uSec)=6480,930,1260,3960,300,330,720,720,300,720,300,330,720,720,300,330,720,330,720,330,720,720,300,330,720,720,300,720,300,330,720,330,720,720,300,720,300,720,300,330,720,720,300,330,720,330,720,720,300,720,300,720,300,330,720,330,720,330,720,300,720,720,300,720,300,720,300,330,720,330,720,720,300,300,720,720,300,1320,1290,3960,300,330,720,720,300,720,300,300,720,720,300,330,720,330,720,300,720,690,300,330,720,720,300,720,300,330,720,300,720,690,300,720,300,690,300,330,720,720,300,300,720,330,720,720,300,690,300,720,300,300,720,300,720,330,720,330,720,690,300,690,300,690,300,330,720,330,720,720,300,300,720,690,300,1320,1290,3930,300,300,720,690,300,690,300,300,720,690,300,300,720,300,720,300,720,690,300,300,720,690,300,720,300,300,720,330,720,690,300,690,300,720,300,300,720,690,300,300,720,300,720,690,300,720,300,690,300,330,720,300,720,300,720,330,720,690,300,690,300,690,300,300,720,300,720,720,300,330,720,690,300,1290,1290,3930,300,300,720,690,300,720,300,300,720,690,300,300,720,300,720,300,720,690,300,300,720,690,300,690,300,300,720,300,720,690,300,690,300,690,300,300,720,720,300,330,720,300,720,690,300,690,300,720,300,330,720,300,720,330,720,300,720,690,300,720,300,690,300,330,720,300,720,690,300,300,720,690,300,1320,1290,3930,300,300,720,690,300,690,300,300,720,690,300,300,720,300,720,300,720,690,300,300,720,690,300,690,300,300,720,300,720,720,300,690,300,690,300,300,720,690,300,300,720,300,720,690,300,690,300,690,300,300,720,300,720,300,720,300,720,690,300,690,300,720,300,300,720,330,720,690,300,300,720,690,300,1320,1290,3930,300,330,720,690,300,690,300,300,720,720,300,330,720,330,720,330,720,720,300,300,720,720,300,720,300,330,720,330,720,720,300,720,300,720,300,330,720,720,300,330,720,330,690,720,300,720,300,720,300,330,690,330,720,330,690,330,690,720,270,720,270,720,270,330,690,330,690,720,270,360,690,750,270,1350,1260,3990,270,330,690,750,270,750,270,360,660,750,270,360,690,360,660,360,660,750,240,390,660,780,240,780,240,390,660,390,630,780,210,780,210,780,240,390,630,780,210,390,630,390,630,780,210,780,210,780,210,390,630;
// Open the door #2
2023-02-06 13:16:15 - 20;B7;DEBUG;Pulses=511;Pulses(uSec)=4590,930,1260,3960,270,330,690,720,270,720,270,330,690,720,270,330,690,330,690,330,690,720,270,330,690,720,270,720,270,330,690,330,690,720,270,720,270,720,270,330,690,720,270,330,690,330,690,720,270,720,270,720,300,330,690,720,300,330,690,330,690,720,300,720,300,720,300,330,690,330,690,330,690,330,690,720,300,1320,1290,3960,300,330,720,720,300,720,300,330,720,720,300,330,720,330,720,330,720,720,300,330,720,720,300,720,300,330,720,330,720,720,300,720,300,720,300,330,720,720,300,330,720,330,720,720,300,720,300,720,300,330,720,720,300,330,720,330,720,720,300,720,300,720,300,330,720,300,720,330,720,330,720,720,300,1320,1290,3960,300,330,720,720,300,720,300,330,720,720,300,330,720,300,720,300,720,720,300,330,720,720,300,720,300,300,720,300,720,720,300,720,300,720,300,300,720,720,300,330,720,330,720,720,300,720,300,720,300,300,720,720,300,330,720,330,720,720,300,720,300,720,300,330,720,330,720,300,720,300,720,720,300,1320,1290,3960,300,330,720,690,300,690,300,300,720,690,300,300,720,330,720,330,720,690,300,300,720,720,300,690,300,330,720,300,720,690,300,720,300,720,300,330,720,690,300,300,720,300,720,720,300,690,300,690,300,300,720,690,300,300,720,330,720,690,300,690,300,690,300,300,720,300,720,300,720,330,720,690,300,1290,1290,3930,300,300,720,720,300,690,300,300,720,690,300,300,720,300,720,300,720,690,300,300,720,690,300,720,300,300,720,300,720,690,300,690,300,690,300,300,720,690,300,330,720,300,720,690,300,720,300,720,300,300,720,690,300,300,720,300,720,720,300,720,300,690,300,300,720,300,720,330,720,330,720,720,300,1320,1290,3960,300,300,720,720,300,720,300,330,720,720,300,330,720,300,720,330,720,720,300,330,720,720,300,720,300,330,720,330,690,720,300,720,300,720,300,330,720,720,270,330,690,330,690,720,270,720,270,720,270,330,690,720,270,330,690,330,690,750,270,720,270,750,270,360,690,360,690,360,690,360,660,750,240,1350,1230,3990,240,360,660,750,240,750,240,360,660,780,240,360,660,390,660,390,660,780,210,390,630,780,210,780,210,390,630,390,630,780,210,780,210,780,240,390,630,780,240,390,630,390,630,780,240,780,240,780,240,360,660;
// Close the door #2
2023-02-06 13:16:17 - 20;B8;DEBUG;Pulses=511;Pulses(uSec)=4620,900,1320,3930,330,300,750,690,330,690,330,300,750,690,330,300,750,300,750,300,720,690,330,300,720,690,330,690,330,300,750,300,720,690,330,690,330,690,330,300,720,690,300,300,720,300,720,690,330,690,300,690,330,300,720,300,720,300,750,300,720,690,300,690,300,690,330,300,720,300,720,690,300,300,720,690,300,1290,1290,3930,300,300,720,690,330,690,300,300,720,690,330,300,720,300,720,300,720,690,300,300,720,690,330,690,330,300,720,300,720,690,300,690,300,690,300,300,720,690,300,300,720,300,720,690,300,690,300,690,330,300,720,300,720,300,720,300,720,690,300,690,300,690,300,300,720,300,720,690,300,300,720,690,300,1290,1290,3930,300,300,720,690,300,690,300,300,720,690,300,300,720,300,720,300,720,690,330,300,720,690,300,690,330,300,720,300,720,690,300,690,300,690,300,300,720,690,330,300,720,300,720,690,300,690,300,690,330,300,720,300,720,300,720,300,720,690,300,690,300,690,300,300,720,300,720,690,300,300,720,690,300,1290,1290,3930,300,300,720,690,300,690,300,300,720,690,300,300,720,300,720,300,720,690,300,300,720,690,300,690,300,300,720,300,720,690,300,690,300,690,300,330,720,690,300,330,720,300,720,690,300,720,300,720,300,330,720,330,720,300,720,300,720,720,300,720,300,720,300,330,720,330,720,720,300,330,690,720,300,1320,1290,3960,300,330,720,720,300,720,270,330,690,720,300,330,690,330,720,330,690,720,270,330,690,720,270,720,270,330,690,360,690,750,270,750,270,750,270,360,690,750,240,360,660,360,660,750,240,750,240,750,240,360,660,390,660,390,660,390,660,780,210,780,210,780,240,390,630,390,630,780,210,390,630,780,210,1380,1200,4020,240,390,660,780,240,780,240,360,660,780,240,360,660,390,660,360,660,750,240,360,660,750,240,750,240,360,660,360,660,750,240,750,240,750,240,360,660,750,270,360,660,360,660,750,270,750,270,750,270,360,690,360,660,360,660,360,660,750,270,750,270,750,270,360,660,360,690,750,270,330,690,750,270,1350,1260,3990,270,330,690,720,270,720,270,330,690,720,270,330,690,330,690,330,690,720,270,330,690,720,270,720,270,330,690,330,690,720,270,720,270,720,270,330,690,720,270,330,690,330,690,720,270,720,270,720,270,330,690;
// Open the door #3
2023-02-06 13:16:57 - 20;C8;DEBUG;Pulses=511;Pulses(uSec)=4590,930,1260,3960,270,330,690,720,270,720,270,330,690,720,270,330,690,330,690,330,690,720,270,330,690,720,270,720,270,330,690,330,690,720,270,720,270,720,300,330,690,720,300,330,690,330,690,720,270,720,300,720,300,330,690,720,270,330,690,330,690,720,300,720,300,720,300,330,690,330,690,330,690,330,690,720,270,1320,1290,3960,300,330,690,720,300,720,300,330,720,720,300,330,720,330,720,330,720,720,300,330,720,720,300,720,300,330,720,330,720,720,300,720,300,720,300,330,720,720,300,330,720,330,720,720,300,720,300,720,300,330,720,720,300,330,720,330,720,720,300,720,300,720,300,330,720,300,720,330,720,330,720,720,300,1320,1290,3960,300,300,720,720,300,720,300,330,720,720,300,330,720,300,720,300,720,720,300,330,720,720,300,720,300,300,720,330,720,720,300,720,300,690,300,300,720,720,300,330,720,330,720,720,300,720,300,720,300,330,720,720,300,330,720,300,720,720,300,720,300,720,300,330,720,330,720,300,720,300,720,720,300,1320,1290,3960,300,330,720,690,300,690,300,300,720,720,300,330,720,330,720,300,720,690,300,330,720,690,300,690,300,330,720,300,720,690,300,720,300,690,300,330,720,690,300,300,720,330,720,690,300,690,300,690,300,300,720,690,300,330,720,300,720,690,300,690,300,690,300,330,720,300,720,300,720,300,720,690,300,1320,1290,3930,300,300,720,690,300,690,300,300,720,690,300,300,720,300,720,300,720,690,300,300,720,690,300,720,300,300,720,300,720,690,300,690,300,720,300,300,720,690,300,300,720,300,720,690,300,690,300,690,300,300,720,690,300,300,720,300,720,690,300,690,300,690,300,300,720,300,720,300,720,330,720,690,300,1320,1290,3930,300,300,720,690,300,720,300,330,720,720,300,300,720,300,720,330,720,720,300,330,720,720,300,720,300,330,720,330,720,720,300,720,300,720,300,330,720,720,300,330,720,330,690,720,300,720,270,720,270,330,690,720,300,330,690,330,690,720,270,720,270,720,270,330,690,330,690,330,690,330,690,750,270,1350,1260,3990,270,360,690,750,270,750,270,360,690,750,270,360,660,360,660,360,660,750,240,360,660,780,240,750,240,360,660,390,630,780,240,780,240,780,240,390,630,780,210,390,630,420,630,780,210,780,210,780,210,390,630;
// Close the door #3
2023-02-06 13:17:00 - 20;C9;DEBUG;Pulses=511;Pulses(uSec)=4710,900,1320,3930,330,300,750,690,330,690,330,300,750,690,330,300,750,300,750,300,750,690,330,300,750,690,330,690,330,300,750,300,720,690,330,690,330,690,330,300,720,690,330,300,720,300,750,690,300,690,300,690,330,300,720,300,720,300,720,300,720,690,300,690,330,690,330,300,750,300,720,690,300,300,720,690,300,1290,1290,3930,300,300,720,690,300,690,300,300,720,690,330,300,750,300,720,300,720,690,300,300,720,690,330,690,330,300,720,300,720,690,330,690,300,690,300,300,720,690,300,300,720,300,720,690,330,690,300,690,300,300,720,300,720,300,720,300,720,690,300,690,300,690,300,300,720,300,720,690,330,300,720,690,300,1290,1290,3930,300,300,720,690,300,690,330,300,720,690,300,300,720,300,720,300,720,690,300,300,720,690,300,690,330,300,720,300,720,690,300,690,300,690,330,300,720,690,330,300,720,300,720,690,300,690,300,690,330,300,720,300,720,300,720,300,720,690,300,690,300,690,300,300,720,300,720,690,300,300,720,690,300,1290,1290,3930,300,300,720,690,300,690,330,300,720,690,300,300,720,300,720,300,720,690,300,300,720,690,300,720,300,300,720,300,720,690,300,690,300,720,300,300,720,690,300,300,720,300,720,720,300,720,300,720,300,330,720,300,720,330,720,330,720,720,300,720,300,720,300,330,720,330,720,720,300,330,690,720,300,1320,1290,3960,300,330,690,720,270,720,300,330,690,720,300,330,690,330,690,330,690,720,270,330,690,720,270,750,270,360,690,360,690,750,270,750,270,750,270,360,660,750,240,360,660,360,660,750,240,750,240,780,240,390,660,390,660,390,660,390,630,780,210,780,210,780,210,390,630,390,630,780,210,390,630,780,210,1380,1200,4020,240,390,660,780,240,750,240,390,660,750,240,390,660,360,660,360,660,750,240,360,660,750,240,750,240,360,660,360,660,750,240,750,270,750,270,360,660,750,240,360,660,360,660,750,270,750,270,750,270,360,660,360,660,360,690,360,690,750,270,750,270,750,270,360,690,360,690,750,270,330,690,750,270,1350,1260,3960,270,330,690,720,270,720,270,330,690,720,270,330,690,330,690,330,690,720,270,330,690,750,270,720,270,330,690,330,690,720,270,720,270,720,270,330,690,720,270,330,690,330,690,720,270,720,270,720,270,330,690;
These sensors should be compatible with Atlantic MD-210R but obsiously they are not ;(
Stuntteam
Site Beheer
#7 Post by Stuntteam » 15 Jun 2023, 14:31
Yes, I see.. (did not make the connection between the mail and forum username.. :))
But that is a different issue..
Both will be solved.
OlivFromBreizh
#8 Post by OlivFromBreizh » 15 Jun 2023, 16:53
Good news !
I'm pretty sure you already know what will be my next question...
Do you know when you will release the fix ? I just want to know if I have to replace my sensors by other ones.
Also if you want I validate your fix, don't hesitate to ask, I will be glad to help.
