Firmware for ESP-01S on flash ZP25WQ80 is not loaded
Posted: 26 May 2023, 10:06
Firmware for ESP-01S on flash ZP25WQ80 is not loaded. get flash id : 0x001460ba manufacturer_id: 0xba device_id: 0x6014
INIT : Booting version: ESP_Easy_mega_20230306_normal_ESP8266_1M_VCC, (GitHub Actions) mega-20230306 (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
5308 : Info : INIT : Free RAM:30072
5310 : Info : INIT : Soft Reboot #3 - Restart Reason: Software/System restart
5311 : Info : FS : Mounting...
5317 : Info : FS : Mount successful, used 1506 bytes of 113201
5323 : Error : FS : Error while reading/writing config.dat in 16498
5325 : Info : INIT : I2C
5326 : Info : INIT : SPI not enabled
5431 : Info : WIFI : Set WiFi to STA
10006 : Info : WIFI : Set WiFi to AP+STA
10117 : Info : WIFI : AP Mode ssid will be ESPEasy- with address 192.168.4.1
12405 : Info : WIFI : Disconnected! Reason: '(1)'
12506 : Info : Reset WiFi.
14793 : Info : WIFI : Set WiFi to OFF
PID:0
Version:0
INIT : Incorrect PID or version!
RESET: Resetting factory defaults... using default settings
RESET: Warm boot, reset count: 3
RESET: Too many resets, protecting your flash memory (powercycle to solve this)
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (0):
epc1=0x4000e25d epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3fff25c0 end: 3fff2850 offset: 0190
3fff2750: 00000001 3fff0eb0 3fff0a08 00000000
3fff2760: 402759ee 00000000 3fff46cc 40275af5
3fff2770: 0000001c 00000000 00000000 00000000
3fff2780: 00000003 00000000 3fff46cc 40275d2a
3fff2790: 3fff1710 00000001 3fff1710 00000000
3fff27a0: 00000000 00000001 3fff1710 4026fe28
3fff27b0: 00000000 3fff1710 0000000a 4027588e
3fff27c0: 00000000 0000001c 00000000 4026fda0
3fff27d0: 3fff1710 3fff0468 00000000 40238b8c
3fff27e0: 3fff0868 3fff0468 3fff0eb0 40238968
3fff27f0: 3fff0000 0036003f 80efeffe 3fff3700
3fff2800: 0000003f 80efeffe feefeffe feefeffe
3fff2810: feefeffe feefeffe feefeffe 3fff289c
3fff2820: 3fffdad0 00000000 3fff2858 4020a3dc
3fff2830: feefeffe feefeffe feefeffe 40272d77
3fff2840: feefeffe feefeffe 3ffe8694 401004dd
<<<stack<<<
ets Jan 8 2013,rst cause:1, boot mode:(3,6)
load 0x4010f000, len 3584, room 16
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
PID:0
Version:0
Exception (0):
>>>stack>>>
ctx: cont
<<<stack<<<
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
