mega-20221224 and HTU21D problem
mackowiakp
#1 Post by mackowiakp » 24 Feb 2023, 02:09
I tried to compile custom_esp8266_4M1M FW based on mega-20221224.
Unfortunately, the measurement results for the HTU21D sensor are not displayed and transferred to Domoticz.
Below screenshots for such FW.
The sensor is properly recognised by "I2C Scan" in "Tools" menu.
It works properly with the earlier version of mega but I don't remember which version it was.
Can it be somehow determined based on a compiled binary file I have? "Strings" in Linux or so?
I attach copy/paste from "Info" menu of properly working binary.
System Info	Copy info to clipboard (⋄)
Unit Number:	1
Local Time:	2023-02-24 02:05:18
Time Source:	NTP
Time Wander:	-0.000 [msec/sec]
Uptime:	0 days 1 hours 20 minutes
Load:	21.39% (LC=1198)
CPU Eco Mode:	false
Boot:	Soft Reboot (0)
Reset Reason:	Software/System restart
Last Action before Reboot:	Background Task
SW WD count:	0
Memory
Free RAM:	15176 (12320 - sendContentBlocking)
Heap Max Free Block:	11104
Heap Fragmentation:	25%
Free Stack:	3600 (1536 - sendContentBlocking)
Network
IP Config:	Static
IP / Subnet:	192.168.0.20 / 255.255.255.0
Gateway:	192.168.0.1
Client IP:	192.168.0.2
DNS:	192.168.0.201 / (IP unset)
Allowed IP Range:	192.168.0.2 - 192.168.0.30
Connected:	29 m 58 s
Number Reconnects:	1
WiFi ❔
WiFi Connection:	802.11n (RSSI -64 dBm)
SSID:	kuchnia (08:96:D7:F1:DF:1E)
Channel:	12
Encryption Type:	WPA/WPA2/PSK
Last Disconnect Reason:	(8) Assoc leave
Configured SSID1:	kuchnia
Configured SSID2:	WiFi-Fritz
STA MAC:	DC:4F:22:39:15:F6
AP MAC:	DE:4F:22:39:15:F6
WiFi Settings
Force WiFi B/G:	false
Restart WiFi Lost Conn:	true
Force WiFi No Sleep:	true
Periodical send Gratuitous ARP:	true
Connection Failure Threshold:	0
Max WiFi TX Power:	17.50
Current WiFi TX Power:	14.00
WiFi Sensitivity Margin:	3
Send With Max TX Power:	false
Extra WiFi scan loops:	0
Use Last Connected AP from RTC:	false
Firmware
Build:⋄	20116 - Mega
System Libraries:⋄	ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support
Git Build:⋄	Skrzypowa: Mar 11 2022 17:28:09
Plugin Count:⋄	33
Build Origin:	Self built
Build Time:⋄	Mar 11 2022 17:28:08
Binary Filename:⋄	ESP_Easy_mega_20220311_custom_ESP8266_4M1M
Build Platform:⋄	Linux-5.15.25-desktop-1.mga8-x86_64-with-glibc2.2.5
Git HEAD:⋄	pygit2_not_installed
System Status
Syslog Log Level:	None
Serial Log Level:	None
Web Log Level:	None
I2C Bus State:	OK
I2C bus cleared count:	0
Network Services
Network Connected:	✔
NTP Initialized:	✔
ESP Board
ESP Chip ID:	3741174 (0x3915F6)
ESP Chip Frequency:	80 MHz
ESP Chip Model:	ESP8266
ESP Chip Cores:	1
ESP Board Name:	PLATFORMIO_ESP12E
Storage
Flash Chip ID:	Vendor: 0xC2 Device: 0x2516
Flash Chip Real Size:	4096 kB
Flash IDE Size:	4096 kB
Flash IDE Speed:	40 MHz
Flash IDE Mode:	DOUT
Flash Writes:	1 daily / 2 boot
Sketch Size:	826 kB (2244 kB free)
Max. OTA Sketch Size:	1019 kB (1044464 bytes)
OTA possible:	true
OTA 2-step Needed:	false
SPIFFS Size:	934 kB (841 kB free)
Page size:	256
Block size:	8192
Number of blocks:	116
Maximum open files:	5
Maximum path length:	32
Re: mega-20221224 and HTU21D problem
#2 Post by TD-er » 24 Feb 2023, 08:55
Is this using older settings from a previous build, or did you flash it to start with new settings?
If it is with settings from an older version, can you maybe delete this task and add it again? I suspect some settings may not have been transitioned properly from older builds for this specific plugin.
Another option is to disable this task and add the same task at another task index, so you can easily compare settings when needed.
mackowiakp
#3 Post by mackowiakp » 24 Feb 2023, 09:08
Yes, I just flash new FW without doing anything with config. Will try to do as You advise.
mackowiakp
#4 Post by mackowiakp » 24 Feb 2023, 13:11
Yes, redefining the sensor resolved the problem.
#5 Post by TD-er » 24 Feb 2023, 13:38
Good to know :)
Users browsing this forum: No registered users and 50 guests
