Bigger LCD 7" +/- and MQTT import
Posted: 08 Feb 2023, 11:38
by mra2ko
I need bigger LCD and import some numbers from MQTT broker, anybody any solution ?
Nextion or Eink or similar ? Real pic of construction ?
Thank
Re: Bigger LCD 7" +/- and MQTT import
Posted: 11 Feb 2023, 14:37
by Ath
For LCD/TFT screens of that size, besides the Nextion models, I have only found displays based on the SSD1963 controller (800x480 pixels), and that's not (yet) supported by ESPEasy.
For getting MQTT values on ESPEasy, you can use the
MQTT Import plugin. Depending on the build used, not all options like filtering and mapping, might be available though.
Posted: 11 Feb 2023, 14:44
by bidrohini
You can use a Nextion Enhanced HMI Intelligent Smart USART Serial Touch TFT LCD Module. You can also use an E-Ink (electronic ink) display.
Since you're facing issues with MQQT, you can take a look at this write-up:
https://www.theengineeringprojects.com/ ... -mqtt.html
It discusses broadly about the MQTT protocol. It features ESP32.
Posted: 11 Feb 2023, 14:51
by Ath
bidrohini wrote: ↑11 Feb 2023, 14:44
That's not what's said, OP just asked how to get values from MQTT on ESPEasy, that's what the MQTT Import plugin is for.
Your link is dead (404), but the
HiveMQ site has a
very elaborate description of the MQTT protocol.
