I recently buy a RFLink 433.42 for control my portal motor, a Somfy Freevia.
I think that I success to pair because of the led turn on on the motor when I did it.
But when I tried to send the command STOP for open or close the portal, nothing happen.
I saw when I use my remote (only one click) :
20;20;Debug;RTS P1;a4f904e652f44cc40019;
20;21;RTS;ID=252f44c;SWITCH=01;CMD=STOP;
20;22;Debug;RTS P2;a4f904e652f44cc80026;
20;23;RTS;ID=252f44c;SWITCH=01;CMD=STOP;
20;24;Debug;RTS P3;a4f904e652f44c880022;
20;25;RTS;ID=252f44c;SWITCH=01;CMD=STOP;
The command seems to be send 3 times with P1 / P2 / P3, is it normal ?
Can this is the issue ?
Hope that someone can help me,
SOmfy RTS
Re: SOmfy RTS
No, thats normal..
Re: SOmfy RTS
So I retry today and when I pair I saw the Led turn on and off.
Then when I send the Stop command the led blink but nothing move, have you any idea ?
Re: SOmfy RTS
I finally succeeded, even the remote send only the command STOP.
With Rflink Loader it's the commands UP and DOWN that control the portal
Thank you for your time
