UDP problem on NSPanel (Nextion) and esp easy
Posted: 31 Dec 2022, 13:03
by kudykam
I have Sonoff NSPanel with ESP Easy Mega fw and I am trying to send UDP command from button on screen to Loxone. Problem is that it is always two commands on separete line.
12 12:48:29.179 Loxone 192.168.20.25 NSPAnel 514 NSPanel_1_disp_idx=12
9 12:48:25.939 Loxone 192.168.20.25 NSPAnel 514 NSPanel_1_disp_value=1
It si sendidn IDX and Value separated, I need it together to be able to read it properly with loxone. Checking "Single event with all values:" doesnt help. It is shown on one line in esp log but it didnt send on one line via udp.
Please help
Re: UDP problem on NSPanel (Nextion) and esp easy
Posted: 01 Jan 2023, 01:53
Are you sending via the ESPEasy p2p?
If so, then you could also send more info via an event.
See:
https://espeasy.readthedocs.io/en/lates ... nd-publish
For example: ( with N being the unit nr to send to)
sendTo,N,"event,MyEvent=123,456,789"
This can then be handled on the receiving end in the rules like this:
on MyEvent do
logEntry,"1:%eventvalue1% 2:%eventvalue2% 3:%eventvalue3%"
Posted: 01 Jan 2023, 10:29
by kudykam
I communicate with Loxone (Entred as a controller).
So this command should be entered into rules?
so on my event:
EVENT: disp#idx=763
EVENT: disp#value=1
the rule will be like this?
on disp do
logEntry,"1:%idx% 2:%value%"
Posted: 01 Jan 2023, 13:44
by Ath
kudykam wrote: ↑01 Jan 2023, 10:29
so on my event:
EVENT: disp#idx=763
EVENT: disp#value=1
on disp do
The
documentation on Rules does have examples on how to use variables in rules, it could be something like:
on disp#all do
logEntry,"idx=%eventvalue1% value=%eventvalue2%"
This requires the checkbox 'Single event with all values' to be set in the Device configuration page of the Nextion plugin.
What controller do you have configured to send the data to Loxone?
Posted: 01 Jan 2023, 14:02
The example I gave was to send the eventvalues to the log so you can see what you receive.
This logEntry command is seriously useful for debugging.
Posted: 01 Jan 2023, 16:50
by kudykam
OK thanks,
and how do I send it do UDP?
Posted: 01 Jan 2023, 16:53
by Ath
Ath wrote: ↑01 Jan 2023, 13:44
Well, that's the question I'm requesting an answer on
Posted: 01 Jan 2023, 17:42
by kudykam
Generic UDP with Loxone IP, controller Nr. 1
Posted: 01 Jan 2023, 19:34
by Ath
I think we are talking about differnt controllers, I've been trying to ask for the ESPEasy Controller, but you seem to point to an external device
In ESPEasy there is the 'SendToUDP,ip,port,commandstring' command. The commandstring you will have to create yourself, where you can use variables to fill in the parameters, as expected by Loxone (their documentation seems quite elaborate)
