Any advice? Automated rotary knob
Hi, Wondering if one of the readers here eventually knows a way to automate a rotary knob like the one pictured.
I do not want to get in touch with anything hiding behind the front panel ..
- rk.jpg (67.36 KiB) Viewed 4213 times
Re: Any advice? Automated rotary knob
You mean like adding some clamp with a servo setting the angle?
This brings the question how much force is needed to rotate it.
Not easy to answer, a hand can do pretty easily.
But I even thought of not getting to deep into the bits and pieces.
Idea came from when I saw this Obviously too weak
Hi, i would like to know what you want to achieve.
Do you need something for just turning the device on and off or just off. (bidirectional or unidirectional?)
Or is it only for switching between heating and heating+warm water?
Hi, switching between heating and heating+warm water would be great, if one direction only is possible that'll help, too
If it is only for two states, i would advise using a servo motor and a kind of attachment to the knob. Unfortunately i don´t have my computer with me, so the sketch is kind of "simple" but i think it makes clear what i mean.
It is advantageous to own a 3d printer for this
Additional infos:
https://espeasy.readthedocs.io/en/lates ... ervo-motor
Edit: i choose this setup because manual override could be still possible dependent on the clearance of the mechanism...
Additional infos:
Perfect excuse to buy one.
Who doesn't have a 3D printer these days?
Or more...
Glad I can also sometimes borrow my dad's printers too, when I really need to print some large batches of enclosures.
A few months ago I had all my room filled with them printing 24/7 for 2 weeks.
That was a lot of planning to keep them occupied all time and also not running out of filament (a box of filament was held at customs..)
Know what you're talking about as/although I don't own one, but for things like these the diy area should provide enough material.
I'm at the moment more afraid of the parts you won't print like all the cables, two differing mains adapters, outlet, ..
There is actually not so much to it.
Assuming you have a wemos d1 mini for example:
There are three cables from the servo to the wemos d1 mini and one usb cable from the microcontroller to the usb power adapter.
Just for info, as one failing should be enough:
the device already shown before is battery operated but can move in one direction only, despite the four arrows .. The chip used looks like an ESP but somehow smaller and not branded.
amazingly the device above was strong enough to turn the heating. However I wasn't able to flash it as I didn't spot the necessary PIN's.
Also Alexa integration worked only partly: linking the device was successful, controlling the device wasn't.
Pity.
Pity.
before moving too deep into the configuration: 'Motor - PWM Motor' is the correct device to choose from (saw that the device's list differs from bin to bin, beg due to memory reasons).
Binary Filename:⋄ ESP_Easy_mega_20221105_custom_ESP8266_1M
ESP Board Name: Espressif Generic ESP8266 ESPEasy 1M Flash 128k FS
Is there a help page or an example available to choose the right values of the many that can be controlled?
I never used a servo. But since the controlling is done via the internal gpio handling (https://espeasy.readthedocs.io/en/lates ... #p000-page) you can just use any build. I´d recommend the ESP_Easy_mega_20221224_normal_ESP8266_1M.bin from the latest release. There is no need to add a device for the servo.
uhm,
589640: HTTP: Servo,1,14,45
589642: SERVO : command not included in build
596422: EVENT: Clock#Time=Tue,15:02
Oh sorry then, i thought this is integrated in all builds. At least I haven't seen any other info about it...
So maybe TD-er reads this and can shed light into this.
Edit: But i guess, since the servos work with PWM, you could also use the PWM command.
no worries, didn't thought it would be that easy to detect why it's not running
To control a servo, you need to use PWM.
But... the pulses sent to a servo are really short.
Also the PWM frequency for a servo is rather low.
So what is done with the servo command is that it will reconfigure the PWM completely different from other typical PWM use cases.
To have some kind of 'resolution' with the servo pulses, we need to use 16-bit counters, where the normal PWM is using 10 or 12 bit counters.
Using the normal PWM command, you cannot get the fine control over those short pulses you need for servos.
We used to have a special library for servos, which adds a significant amount to the build size, but I'm not sure we still do.
If we don't then I don't think leaving the servo command out and having PWM commands in the build is going to make a lot of difference in build size.
not sure if I understood that correctly ..
I'm now trying with a test installation on an ESP32, no memory restrictions.
Servo is working, I'd say okay.
Is there a chance to stop preventing the servo from continuous positioning', let's say half a second after firing the command?
Oh, maybe I simply need to set GPIO pin to low.
I'll then try to build my own ESPEasy version, not sure if I'll manage, Linux and Arduino are set up but this isn't everything here
Also not sure if that'll fit into 1M or if I'd rather go on collecting parcel deliveries
See:
https://espeasy.readthedocs.io/en/lates ... ernal-gpio
A position value of 9000 will stop the PWM signal. This can be useful to save energy on servos which do not need power to remain at the same position.
Please use VSCode with PlatformIO for development, as that's the endorsed configuration: https://espeasy.readthedocs.io/en/lates ... ormIO.html
It contains a section specifically aimed at developers new to ESPEasy-development.
upuh, wanted to use less not more
Software as well as servo control are working fine.
I also found a nice place to mount the servo so it will not disturb.
Unfortunately, I didn't manage to turn the switch by using a servo.
The switch has an approx. 3cm long spindle which is then attached to the onboard switch - which I obviously doesn't want to modify.
If I attach the servo to the switch like in a model airplane (metal linkage?), everything somehow gets twisted and is not turning correctly, reliably. Yes, I know, 3D-printing, but with having none, the solution to the problem needs to be different
