Some OT before bedtime:
1.
Sysinfo VCC shows 3.469V but real they are 3,286V (Aneng A3008, Metex M-4650, McVoice M-980T --> +/- 3mV). So it shows round about 180mV too much of. This is with all ESP's I just check (two S20, two ESP-07, one ESP-07S, one D1miniPRO)
Is there a way to calibrate that at the root without change the code and recompile and not with a Formular?
2.
If I use GPIOtoggle,13 and GPIO13 is set as WLAN->LED in "Hardware" the log show me ...
ACT : GPIOtoggle,13
GPIO : port#13 is not an output port
If I set WLAN->LED to none then it worked like expected. You ask about the funny thingy in this?
At 1st GPIO13 is always an output-port and 2nd if you use "longpulse,13,*" or simple "GPIO,13,1/0" you can manipulate GPIO13 as well. So why not with toggle? I Don't get that ...
Good n8 all ...
