What is the recommended firmware for the ESP12F Relay X1 (V1.2) board
It has a 4MB flash.
Tried ESP_Easy_mega_20221122_normal_ESP8266_1M_VCC (because i used it in a former project) - runs good.
But with the 4MB flash i think it would be better to use a 4M1M version.
But which?
Is the ESP_Easy_mega_20221105_normal_ESP8266_4M1M a good choise?
Greeting
Thomas
Firmware for a ESP12F Relay X1 (V1.2) board
Re: Firmware for a ESP12F Relay X1 (V1.2) board
Yep, that's a good one.
Do you need to measure the internal supplied 3V3 or an external analog voltage (the _VCC build measures the voltage supplied to the ESP, the others measure from the external A0 pin)
But... I suggest you use the file from this test build:
https://github.com/letscontrolit/ESPEas ... 3660056475
It has a number of fixes, including making WiFi (re)connect much more reliable and faster.
